Rolling on 205/50/15 on my 94 Civic, would my car look lowered if I sport 195/50/50????
Old May 25, 2008 | 08:09 AM
dj theoretic's Avatar
Default Rolling on 205/50/15 on my 94 Civic, would my car look lowered if I sport 195/50/15????
Need New tires and wanted to know if my my car would look more lowered to the ground if I sport 195/50/50???? I have a 94 Civic Coupe rolling on 205/50/15??? my car is lowered as well.
Modified by dj theoretic at 12:29 AM 5/26/2008
Old May 25, 2008 | 08:37 AM
Never mind (too many people look; but don't help) I decided to use my brain and I came up with the Conclusion that it would be at the same height just more gap between the tire and the fender. [freak] I'm smart.
Old May 25, 2008 | 08:47 AM
alphalanos's Avatar
Default Re: (dj theoretic)
it will be the same unless you use an improper tire size. if you want it lower than you need to change suspension. Although going more then 1.5inches or so has a negative effect on handling and wear of tires and other suspension parts.
Old May 25, 2008 | 08:56 AM
labtec2's Avatar
lol i wouldn't pat yourself on the back for basic *** knowledge. all you had to do anyway was think about it....
so after "lifting your car" lets face it with a lot of fender gap it looks like its up in the air anyway, (it happend when i had my 205/40/17) and looked bad with the stock tires until i put the lowering springs on
and i think i misunderstood when you titled your thread 195/50/50 which would assume you want 50-inch wheels... 50 sidewall and 195 width
Old May 25, 2008 | 09:07 AM
90_EX_Civic's Avatar
Old May 25, 2008 | 06:37 PM
pimpvw's Avatar
Default Re: (90_EX_Civic)
http://www.miata.net/garage/tirecalc.html
Old May 25, 2008 | 11:28 PM
I know it was a typo LOL ! I been using 205/50/15 for the past 5 years on my car and want to down grade to a 195/50/15 just because. Before i do that i want to see if anyone would tell me if my car would have a different look... I know that the Width is 205 and it's good on a tire, but going smaller might be a good idea or not a good idea for some. Just need peoples opinion because it seems to me that people that have there cars lowered and use the 195/50/15 tires on their car it looks good rather the 205... in a unusual way.
Old May 26, 2008 | 06:30 AM
ShortyzKustomz's Avatar
Its hardly a difference, Im actually running 205/50s on the back and 195/55s up front now, just cause I needed tires and had some 195s, Its just a hair taller tire, and just a hair narrower. It works well for me cause my car is slammed and with the wheel at full lock Im about 1/4 inch from rubbing
Modified by ShortyzKustomz at 7:35 AM 5/26/2008
Old May 26, 2008 | 10:10 AM
user 98292739's Avatar
i am dropped 4 inchs on 205/50/15s
i dont have a finger gap:-D hehe
rexfan
Mar 16, 2007 10:31 AM
SpeedingHatch
Mar 10, 2006 06:48 AM
TheTealHatch
Feb 26, 2006 05:19 PM
litterbox
22
Feb 24, 2005 01:54 PM
SIK IN DA HED
Aug 3, 2002 01:13 AM
