Timing Belt Broke
Old Jul 15, 2002 | 06:20 PM
SIKSI's Avatar
New User
Default Timing Belt Broke
Well my 1990 crx si is in the shop and yep the timing belt broke. The mechanic also said that i bent some valves. My mechanic also said that the waterpump needs to be replaced. Now my question is, for $800 is this a good price to fix it. It seems quite over priced? what do you guys think. or should i just do a b16a1 swap which will cost like $1800 total.
thanks for your help in advance jason
Old Jul 15, 2002 | 06:41 PM
therealciviczc's Avatar
Default Re: Timing Belt Broke (SIKSI)
Personally I think $800 is waaaayyyy to much money to sink in to a D16A6 that is only going to be as good as stock when you're done. You can get a used motor for way less than that and drop it in. You can get a ZC for $500 or so and drop it in and still be under $800. I'd be surprised if you could have a complete B16 swap done and running for only $1800 though. I'm not saying its impossible, but as many here will tell you, there are always lots of unforseen costs.
anyway, skip sinking $800 in to a stock A6 motor and go swap, or go used. A Z6 is another great option that should be able to be put in the car for well under $800.
Old Jul 15, 2002 | 06:43 PM
bryant's Avatar
Default Re: Timing Belt Broke (therealciviczc)
I agree. You could even pick up another A6 for $200
Old Jul 15, 2002 | 06:50 PM
4gvtec's Avatar
$800, tell them to kiss your ***!!!!!!!!!!!!!!
bent valves, i dont think so. its not a dsm.
how does he know the valves are bent with the head still on the car????????????
Old Jul 15, 2002 | 07:59 PM
SIKSI's Avatar
New User
Default Re: Timing Belt Broke (4gvtec)
hey what is a dsm? and yeah he did take off the head to check. but thanks for all the advice guys. i think i will go with a swap.
Old Jul 15, 2002 | 08:03 PM
4gvtec's Avatar
dsm is mitsubishi,very very close tolerance on the piston to valve clearance.how did he check the head for bent valves?and did he show you the bent valve?
oh dsm:diamond star motors
[Modified by 4gvtec, 5:04 AM 7/16/2002]
Old Jul 15, 2002 | 10:17 PM
Malgerus's Avatar
Yeah I blew the belt on my A6 in januray. Just pulled the head tonight. Turns out everything is fine! Oh well, it was a good excuse to do a swap... SOHC VTEC all the way!! Too bad Honda engines aren't like Mazda MX-6 V6's... non interference engine!
Old Jul 16, 2002 | 12:36 AM
rice_classic's Avatar
Default Re: Timing Belt Broke (89_Y_49)
1800$ for b16 swap.. nope, never happen if you want it to last long.
2500$? now we're talkin'.
Old Jul 16, 2002 | 07:23 AM
SpooN Man's Avatar
Default Re: Timing Belt Broke (rice_classic)
Ya i too thought 1300 and my swap would be in and running.
2500 later and it's doing fine
Old Jul 16, 2002 | 07:52 AM
Ditto... I broke my girlfriend's T belt at about 80mph in 5th gear on the highway. No valves were bent at all. This was also an A6 motor. I have heard of people bending valves on the A6 though. I suppose it depends on various factors.
Old Jul 16, 2002 | 06:16 PM
SIKSI's Avatar
New User
Default Re: Timing Belt Broke (SpooN Man)
what kind of problems did you run into while doing the swap? i might not do the swap after all since the car is like 12 yrs old and the body isn't that of good shape either. i probably would just get rid of it. thanks for all the help guys
h22mark
Apr 25, 2007 07:44 AM
b16_madman
May 28, 2005 06:11 PM
carracr625
Jul 3, 2004 07:16 AM
JokerTypeR
18
May 18, 2004 05:43 PM
Carp
10
Oct 9, 2001 08:34 PM
