finally boosted, got dyno sheet too!
Old Jul 15, 2002 | 06:15 PM
ceemarun's Avatar
Default finally boosted, got dyno sheet too!
this is at .45 bar. sorta disappointed in the power, but hey, its at ~6psi. damn dyno's are loud, but this whole turbo ride has become a great experience. thanks everyone on here.
edit: dammit, doesnt show! anyone want to host a pic for me?
[Modified by ceemarun, 3:16 AM 7/16/2002]
[Modified by ceemarun, 3:17 AM 7/16/2002]
Old Jul 15, 2002 | 06:18 PM
dustin's Avatar
Default Re: finally boosted, got dyno sheet too! (ceemarun)
shows up for me
CovertFI's Avatar
that is good
Old Jul 15, 2002 | 06:19 PM
ceemarun's Avatar
Default Re: finally boosted, got dyno sheet too! (CovertFI)
nevermind
so is that power sorta normal for .45 bar? im sorta disappointed til i boost more.
Old Jul 15, 2002 | 06:24 PM
dustin's Avatar
I take the 5th.
Old Jul 15, 2002 | 06:27 PM
BoOsTeD_eK's Avatar
Default Re: finally boosted, got dyno sheet too! (dustin)
what is that dip at around 5K rpm?
Old Jul 15, 2002 | 07:05 PM
giooooo's Avatar
Default Re: finally boosted, got dyno sheet too! (BoOsTeD_eK)
"Columbia University Mech Eng. Student by day Boost addict by Night!"
damn Columbia...... mad props.. ever heard of cooper union?
Old Jul 15, 2002 | 07:48 PM
Boost2NA's Avatar
Those are pretty good numbers for 6 psi. I wouldnt be ashamed of that at all. It almost looks like your v-tec is engaging to early ( power drop around 5k). But overall nice numbers.
Old Jul 15, 2002 | 08:37 PM
BoOsTeD_eK's Avatar
Default Re: finally boosted, got dyno sheet too! (Giovannie)
yeah great engineering program at that school...did you get accepted?
Old Jul 15, 2002 | 08:40 PM
VaporTrail's Avatar
New User
Default Re: finally boosted, got dyno sheet too! (Boosted99Si)
that looks to be his baseline run. Run 005 is perfectly smooth, as smooth as a baby's ***. Power under the curve is pretty impressive bro, nice work for 6psi
Old Jul 15, 2002 | 09:04 PM
lucas569's Avatar
ahem thank who????? lucas569 who spent countless IM's w/ ceemarun j/k bro nice #'s
Old Jul 15, 2002 | 09:10 PM
BoostinDC2's Avatar
Default Re: finally boosted, got dyno sheet too! (lucas569)
nice numbers for 6psi
Old Jul 15, 2002 | 09:19 PM
Mr. Softee's Avatar
Default Re: finally boosted, got dyno sheet too! (BoostinDC2)
post the a/f ratio!
Old Jul 15, 2002 | 10:21 PM
moo's Avatar
moo
you should boost it up to 9psi or 6.5 bar( i think it should save for you set up) . you might get around 270-280hp at the wheel. i just went dynosport last month i got 280hp with 200 torque with 10psi stock ecu. i might go back again in 2 week and boost it up to 15psi with new ecu(standalone+800cc).
Old Jul 15, 2002 | 11:36 PM
ceemarun's Avatar
Default Re: finally boosted, got dyno sheet too! (94goldjungsr)
post the a/f ratio!
this is all they gave me
Old Jul 15, 2002 | 11:43 PM
Sonny's Avatar
It looks like Lawrence set you up with a nice conservative tune. He probably saw that you were a boost newbie and a Hondata newbie and played things safe. Good for him and good for you.
Sonny
Old Jul 15, 2002 | 11:47 PM
ceemarun's Avatar
Default Re: finally boosted, got dyno sheet too! (Sonny)
Sonny
who you callin newbie?? you mean he could've written it, squeezing out more power? i told him specifically this is for a daily driven car. the car died out terribly and check engine came on when i left, but he took care of it. dynospot =
Old Jul 15, 2002 | 11:56 PM
Sonny's Avatar
Hell yeah he could've written it for more power. Lawrence knew that car as a daily driver, so he played it conservative. The goal of a daily driver is exactly that...to be a daily driver.
If you didn't ask for an a/f ratio printout with your dyno sheet, than you were most certainly branded a "newbie".
Sonny
Old Jul 16, 2002 | 12:22 AM
SIK IN DA HED's Avatar
New User
not bad.
Old Jul 16, 2002 | 02:56 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: finally boosted, got dyno sheet too! (dlplayboy)
What kind of Dyno is it on?
I thikn the numbers are fine actually. I can only hope to get that much with my custom turbo.
See what kind of times you get, then see how you feel.
Is it tuned? Hondata???
[Modified by Snafu-Si, 6:57 AM 7/16/2002]
Old Jul 16, 2002 | 03:55 AM
blkDOHCsol's Avatar
New User
Default Re: finally boosted, got dyno sheet too! (Snafu-Si)
This is tuned with HONDATA.??!?!? I mean the curve looks nice...but the peak is kinda low, right?
Old Jul 16, 2002 | 04:39 AM
Charlie Moua's Avatar
what is your setup? and in what car/motor?
Old Jul 16, 2002 | 11:39 AM
ceemarun's Avatar
Default Re: finally boosted, got dyno sheet too! (Charlie)
99 gsr, hondata 2b, tuned, drag 3 kit, 450cc's, its in my sig
Old Jul 16, 2002 | 01:19 PM
integra-modder's Avatar
Default Re: finally boosted, got dyno sheet too! (blkDOHCsol)
The car is tuned for daily driving.
Old Jul 16, 2002 | 01:48 PM
ceemarun's Avatar
Default Re: finally boosted, got dyno sheet too! (integra-modder)
this is w/ the air/fuel
