b18 timing belt issue
well im having timing issues think the belt skipped a tooth is there a way to check the cams to see if it skipped at tooth? like is there a mark on the cams that indicate TDC?
the are lines on the cam gears on the inside and outside they should line up. And the tops of the cam gears should say 'up'
And on the crank pulley there is a little mark that will line up with a rib looking thing the the lower timing belt cover
efyou
Jul 1, 2006 10:07 AM
Thrillhouse
Aug 9, 2004 02:47 PM
