Snapped Timing Belt on H23 VTEC , The Results Are In...
Old May 24, 2008 | 08:07 PM
LudeyKrus's Avatar
Default Snapped Timing Belt on H23 VTEC , The Results Are In...
Aaaaaaaaaaannnnnnnnnnnddddddddddddddddddddd survey says:
No bent valves!
I must admit I was a bit pessimistic about things, since I was cruising on the interstate and couldn't remember the RPM's I was sitting at (lowered VTEC xover could cause problems)....and tomorrow I have to leave Atlanta to go to Charlotte for five weeks. I just swapped in the new timing belt and she's back alive.
For the record, this is a USDM H22 piston'd, H23 rod, stock valvetrain H23 VTEC.
Old May 24, 2008 | 10:26 PM
98vtec's Avatar
moderator emeritus
Default Re: Snapped Timing Belt on H23 VTEC , The Results Are In... (LudeyKrus)
you lucky summa bitch. The noobs of the year would have a shattered piston. You realize this right?
and where the hell have you been?
Old May 25, 2008 | 03:17 PM
G2IntegraGS's Avatar
Wow. Hows the piston to valve clearance on your build? Is it still an interference motor?? Thats just crazy. Did you not replace the t belt when building it? Or have you actually put 60K+ on the motor?
Old May 25, 2008 | 03:27 PM
ethereal2pt2's Avatar
Default Re: (G2IntegraGS)
wow i wish i could have said the same for my old motor.. lucky man.
oSrBo
Mar 20, 2013 06:54 AM
Hawkze_2.3
Feb 17, 2007 08:24 PM
H23vtecEG
Jan 30, 2006 09:30 AM
AK_94LUDE
Dec 9, 2004 11:18 PM
