Car bogging/almost dying in Neutral when warm?
Old May 24, 2008 | 06:05 PM
foam's Avatar
Default Car bogging/almost dying in Neutral when warm?
When I hit a red light while driving when the car is warm, the RPM almost drops to 0 and sits really low like its about to die and then jumps back up to closer to normal if I wait. It may die when I shift to neutral when the RPM's are really high.
I'm trying to think about what could be the problem? I don't think it's a vacuum leak, I tried to check as best as I could. My other thoughts may be the IACV? Possibly a loose ground?
Car is a del sol single cam turbo.
Modified by foam at 7:16 PM 5/24/2008
Old May 24, 2008 | 08:45 PM
Davus's Avatar
Default Re: Car bogging/almost dying in Neutral when warm? (foam)
... Oxygen sensors can typically do this, and for cars our age it's about time to replace.
I dropped a brand new Denso o2 sensor into my exhaust manifold, and that issue was solved.
Old May 24, 2008 | 08:54 PM
KangBanger's Avatar
yea mine started doing that recently and i have a single cam turbo as well
if you happen to fix the prob
plz let me know how you fixed it
Old May 24, 2008 | 09:44 PM
foam's Avatar
Default Re: Car bogging/almost dying in Neutral when warm? (Davus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davus &raquo;</TD></TR><TR><TD CLASS="quote">... Oxygen sensors can typically do this, and for cars our age it's about time to replace.
I dropped a brand new Denso o2 sensor into my exhaust manifold, and that issue was solved.</TD></TR></TABLE>
I will look into that thanks. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KangBanger &raquo;</TD></TR><TR><TD CLASS="quote">yea mine started doing that recently and i have a single cam turbo as well
plz let me know how you fixed it </TD></TR></TABLE>
If I ever figure it out I will
patrick_yi_82
Sep 9, 2013 06:10 AM
rhdune16
Nov 26, 2005 09:33 AM
Grease Monkey
Nov 20, 2003 07:50 PM
drunk
Dec 29, 2002 11:43 PM
B_1_8_hatch
Sep 10, 2002 06:44 PM
