New Clutch Slips
Old Jul 15, 2002 | 05:52 PM
matht27's Avatar
Default New Clutch Slips
We just had a new clutch and pressure plate installed in a 1991 Accord. The clutch worked fine then started to slip. It quit slipping, but now it is slipping again. The fluid level is ok. Please Help. Tim
Old Jul 15, 2002 | 05:58 PM
Razor's Avatar
Default Re: New Clutch Slips (matht27)
pressure plate
Old Jul 15, 2002 | 05:59 PM
FastechAccord's Avatar
Did you have the flywheel resurfaced??
Old Jul 16, 2002 | 02:31 AM
niedejb's Avatar
Default Re: New Clutch Slips (EvoAccord)
Check you oil and tranny fluid. You may be getting one of these on the clutch disc.
Old Jul 16, 2002 | 04:24 AM
YeuEmMaiMai's Avatar
take it back to whomever did it. if you have an oil leak around the rear main seal they MUST have seen it.
If there is no leak they did a **** poor job and need to do it again
Old Jul 16, 2002 | 04:30 AM
John's Avatar
New User
It's quite possible that didn't break your clutch in correctly and your glazed your flywheel. Over time, you'll be able to break in the clutch, but it seems taht you glazed the flywheel again. I'd recommend having the flywheel resurface and replacing the clutch disc.
Old Jul 16, 2002 | 04:34 AM
Brandon's Avatar
Life is Suffering
Default Re: New Clutch Slips (DunReit)
Reminds me of what happened with my friend's clutch. He got a good idea to try to burn out the first day he got it. It slipped so bad in first gear he couldn't even get it home. I think it is time for a new disc too.
EDWINV00SI
24
Oct 13, 2011 06:08 PM
aZnjCC
Mar 6, 2006 07:09 AM
allmotor99lude
Jul 7, 2005 08:01 PM
vishyncsu
Oct 7, 2004 10:38 AM
danny98r
Jun 24, 2004 12:15 PM
