what can i do now?
Old May 23, 2008 | 09:20 PM
949's Avatar
949
Default what can i do now?
i sprayed brake cleaner on the trany's throwout bearing.
it was an accident that i did it. i was curious what damage did i do and if there is anyway to fix it?
Old May 24, 2008 | 07:26 AM
91blackEF's Avatar
Default Re: what can i do now? (949)
you can try wd-40 to get it out of there even thought wd-40 is for water displacement but you might have to re grease it cause the brake clean will most likely eat the grease out of the bearing until it grinds up or seises up
Old May 24, 2008 | 08:38 AM
949's Avatar
949
is the bearing openable? i thought it was sealed.
if i can open it what type of grease should i use?
Old May 24, 2008 | 09:13 AM
sgallagher's Avatar
Default Re: (949)
You should be fine. You cannot open the bearing.
If you're that worried about it just replace it, they are not very expensive.
Old May 24, 2008 | 10:12 AM
949's Avatar
949
since i got this as part of an exedy clutch kit. would any throwout bearing also work? or are they different in specs?
Old May 24, 2008 | 06:08 PM
efsublime's Avatar
yeah get a honda one.
civic ef
May 29, 2012 01:02 AM
heavy duty
Mar 12, 2010 01:16 PM
spens 91 Ef
29
Mar 8, 2009 08:15 AM
litterbox
14
Jul 20, 2005 11:33 AM
The Toecutter
Apr 24, 2002 07:24 PM
