Will ELD CEL occur when using no alternator?
Old May 23, 2008 | 08:07 PM
rice is nice's Avatar
Default Will ELD CEL occur when using no alternator?
So I just threw a motor into my drag car to "mock up" the wiring and everything else, and currently do not have an alternator, only CEL is for ELD, is this due to the alternator? Also, when I checked disable ELD on my hondata s300, the cel kept coming up in DTC's window in hondata. Is that normal?
Old May 24, 2008 | 01:56 AM
gibsanez's Avatar
Default Re: Will ELD CEL occur when using no alternator? (rice is nice)
Come on, I'm sure you could have figured this out on your own. Start the car with no alternator charge, and you get a CEL for Electrical Load Detector.....
Do the math.
Old May 24, 2008 | 07:41 AM
Default Re: Will ELD CEL occur when using no alternator? (gibsanez)
the eld isn't in the alternator, its in the fuse box, this I know. There is still electricity coming from the battery of course. No need to be a dick, ALSO, i'm pretty sure i've run another crx before with no alternator and never got a check engine light.
Don't just answer cuz you THINK you know the answer, answer if you KNOW the answer.
Old May 25, 2008 | 09:43 AM
up
JasinC19
Sep 5, 2013 08:03 PM
bengay
Aug 1, 2009 08:45 AM
huge230
Aug 22, 2008 08:28 AM
allanonjj
Apr 14, 2007 03:08 PM
fowler!
Aug 2, 2001 11:58 PM
