GS-R Build Questions
I've got a stock 2000 GS-R with the factory add on lip... I'm gonna drop it a couple inches and as far as body work goes that's all I'm doing. I have to buy the stock tail lights to replace the gross Euro ones that someone put in there.
Other than that, does anyone have any suggestions for me before I start building it? It's completely stock, B18C1, all stock. I'm pretty new as far as Honda's go, I know the basics and a lot about integras but as far as engine builds, I'm a newb. Is the B18C1 in the right condition stock to start building it? Should I try to get a hold of an ITR block or something? Any suggestions/ideas would be greatly appreciated. Don't be afraid to throw something out there, I wanna hear all angles before I start putting cash under the hood.
Thanks everyone!
Thanks everyone!
first you have to ask yourself if you are going Natrualy aspried* or turbo, 2nd. look for power goals.
if your trying to spruce it up just a litttle bit bolts ons. and chipped s100 hondata. if your doing a turbo project looking for more than 400+ hp to the wheels i would sleeve the block, use Brian crower cams, comp cams, a name brand. any after market valve terrain will do. dont oversize not needed
just clean the head have a head job done and you be fine with the stock guides , and after market valves srpings and retainers, buy forged low compression pistons i would go with 9:1 coated pistons. weisco supertech , forgerd rods, eaither manely or Eagle h beams, arp head studs main studs and fly wheel bolts. a light weight flywheel is not rec. for a turbo project but would help if your going with a huge *** turbo, buy a new oem b18c1 top and bottom gasket kit. oem honda water pump oilpump and timing belt kit, aftermarket intake manifold. i would go with either a sheet metal intake or a skunk2
go with a larger diameter tb., and either a fullrace ramhorn or fulllrac e top mount manifold for the turbo. fmic, get new fuel rail, NOT the aem high flow, they are usually used for looks and for NA applications. 990cc-1100cc injectors s300 hondata chipped ecu, AND lsd kit for the trans with upgraded axels. driveshaft shopp level 3.5 should do the trick.
all this is for a top notch engine of course. im building and boosting for about 700+ to the crank and about 55-600 to the wheels.
another good tip
do not buy ebay junk
get ripped off and no warrentees most of the time.
heres a site for great discounts on parts.
http://www.yoparts.com
they have hooked me up alot! i mean ive put about 3k in this winter but if bought retail would ahve been about 5k pm tom at yoparts. hes a mod here on h-t and ask him about it he will hook you up tell him singlesexyshane sent you. hell be honest with you and get you started int he right direction.
goodluck pm me with any specific questions
shane
another good tip
shane
