only 2 cylinders fireing
alright i have a 92 civic ex and i am putting in a b18b in it! problem right now cylinder 1 and 3 are fireing but the other two are not!!!i changed spark plugs i changed wires and i have spark on all 4 cylenders when i spray starting flued in it fires on all 4! i switch out the injectors with others but still the same problem! how likely would it be that the injectors i got were bad to??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikester1222 »</TD></TR><TR><TD CLASS="quote">like what exactly should i check for wireing??</TD></TR></TABLE>
firing order maybe ?
did u check for compression?
intake gasket leak?
intake gasket leak?
Layziejoe775
Jan 25, 2008 08:19 AM
