piston?!!!!!!!!!!!!!!!!!!!!
Old May 23, 2008 | 06:42 PM
efking1985's Avatar
Default piston?!!!!!!!!!!!!!!!!!!!!
will oversized piston fit a stock bore?
for example 81.5mm piston in a b16 stock 81.mm block?
Old May 23, 2008 | 06:45 PM
jimmy o.'s Avatar
no you'll have to bore it over some
Old May 23, 2008 | 06:57 PM
geebs's Avatar
Default Re: (jimmy o.)
think about that.. you have an 81mm bore cylinder.. you want to put a 81.5mm diameter piston into that 81mm bore.. will it fit? say you have a 15" tire.. will a 17" rim fit in there?
EusebioSam19
Oct 28, 2012 06:39 AM
eddiebuiltEK.
Sep 15, 2009 08:25 PM
Yambor
Apr 29, 2005 10:55 PM
Mr. Vapor
Dec 19, 2002 01:19 PM
