Engine coatings are they worth the $$
What engine coatings BANG 4 the BUCK and what are the benifits of coating each peice
Please list the benifits individuallly if you have experience
http://www.pure-tuning.com/pag...s.htm
How do engine coating on the rotating assembly stack up to micropolishing components
for my builds i usually only do piston skirts and domes...bearings are a nice option as well but not mandatory...skirt coatings really help buffer the pistons as they move along the sleeve
there usually coated after the clearances are established...but yeah they somewhat tighten things up but as the crank turns and the engine is turned off so many times they buffer into the main journals...so it really isn't a big deal later on...
swaintech coats their bearings to about .0002" a shell(.0004" included) or somewhere around there as I remember from their site...
I am pleased to learn today that the RS 84.5mm slugs already have a Molyb heat and friction coating on the skirts
I'm not sure If any other coatinngs will yeild the performace gain or characterics I am seeking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elwuudz »</TD></TR><TR><TD CLASS="quote">I am pleased to learn today that the RS 84.5mm slugs already have a Molyb heat and friction coating on the skirts
I'm not sure If any other coatinngs will yeild the performace gain or characterics I am seeking</TD></TR></TABLE>
You need to actually know what youre talking about first.
read around on this site. they have some good info
http://www.techlinecoatings.com/introduction.html
I am hoping to alleviate any confusion I might have; first by asking specific questions in this forum.
Maybe I should have used some of the industry specific terms like the RS piston skirts have a TBC to reduce friction and reduce heat soak.
I feel if I waste my time confusing myself with the finite science of engine coatings ; this could hinder my potential knowlege in other vital areas.
