wheel stuck
Old May 23, 2008 | 06:29 PM
freshkid_4's Avatar
Default wheel stuck
i have a 1990 crx it has been sitting for a while and the back left tire is siezed up how can ge it unsiezed and help would be great thanx and oh yah i tried dragging it to get it unsiezed back and forth and would not budge and other spins fine
Old May 23, 2008 | 07:34 PM
zrickety's Avatar
Default Re: wheel stuck (freshkid_4)
you will probably have to remove the wheel and hit the drum or disc with a hammer...the bigger the better, and break the rust loose. then try removing the drum or caliper and oiling everything underneath. a long pry bar might help too...i've been there before, good luck
Old May 23, 2008 | 11:02 PM
ef 4 door's Avatar
Default Re: wheel stuck (zrickety)
you may also try some penetrating oil to help. you may try wd-40, pb blaster, knocker loose can help. when all else fails the big hammer will do!
Old May 23, 2008 | 11:20 PM
pandarex's Avatar
Default Re: wheel stuck (ef 4 door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zrickety &raquo;</TD></TR><TR><TD CLASS="quote">you will probably have to remove the wheel and hit the drum or disc with a hammer...the bigger the better, and break the rust loose. then try removing the drum or caliper and oiling everything underneath. a long pry bar might help too...i've been there before, good luck </TD></TR></TABLE>
x2
Old May 24, 2008 | 07:18 AM
91blackEF's Avatar
Default Re: wheel stuck (pandarex)
if you have drum in the rear heat it up with a propane torch n hit the **** out of it with a big hammer thats how thier going to do it at any automotive shop and when you get that off on the top under the drum there will be a adjustment wheel it looks like a small gear you can turn with a flat head screw driver dont turn it to much though it will adjust the pads inside the drum if thats whats keeping it from moving but also use the pb blaster that **** works wounders with rust...
Old May 24, 2008 | 09:27 AM
Crx Jimmy's Avatar
Default Re: wheel stuck (91blackEF)
as stated before just beat the crap out of the drum, then have someone pull/tow the car down the road
Old May 24, 2008 | 09:48 AM
freshkid_4's Avatar
Default Re: wheel stuck (Crx Jimmy)
ya well im just looking for the easiest way out of this just a temporary fix so i can tow it to the new owners house dont really care if the brake works
efkilla
Dec 6, 2007 01:31 PM
RA102725
Mar 22, 2007 12:36 PM
SeattleBoy
Suspension & Brakes
Apr 26, 2005 07:02 AM
BloodStorm
Feb 15, 2005 10:57 PM
dclub01
Jul 4, 2003 06:29 AM
