need a list of all aftermarket camshaft specs.
can someone post a link to where i can find all aftermarket camshaft spec's please. i think it was on here a few months ago. thanks
edit: JUN,Toda, Skunk and spoon in particular
[Modified by MaliceGSR, 5:06 PM 7/15/2002]
Posted awhile back by Trust - Saved into Notepad
Toda A's
INTAKE lift - 11.6 mm, duration - 250 @ 1mm
EXHAUST lift - 11.2mm, duration - 240 @ 1mm
Toda B's
INTAKE lift - 12 mm,duration - 255 @ 1mm
EXHAUST lift - 12 mm, duration - 245 @ 1mm
Toda C's
INTAKE lift - 12.5 mm,duration - 255 @ 1mm
EXHAUST lift - 12.5 mm, duration - 255 @ 1mm
Jun Type 1
INTAKE lift - 10.9 mm, duration - 265.3 @ 1mm
EXHAUST lift - 10.0 mm, duration - 268 @ 1mm
Jun Type 2
INTAKE lift - 12.0 mm, duration - 266.6 @ 1mm
EXHAUST lift - 10.9 mm, duration - 265.3 @ 1mm
Jun Type 3
INTAKE lift - 12.0 mm, duration - 265.3 @ 1mm
EXHAUST lift - 11.5 mm, duration - 265.3 @ 1mm
Spoon Integra VTEC cam
INTAKE lift - 11.53 mm, duration - 256 @ 1mm
EXHAUST lift - 11.13 mm, duration - 245 @ 1mm
Skunk2 cams
INTAKE lift- 11.58 mm, duration 252 @ 1mm
EXHAUST lift - 10.9 mm, duration 249 @ 1mm
Crower 63403
INTAKE lift - 11.98 mm, duration - 246 @ 1mm
EXHAUST lift - 11.83 mm, duration - 238 @ 1mm
ITR
INTAKE lift - 11.5 mm, duration - 240 @ 1mm
EXHAUST lift - 10.5 mm, duration - 235 @ 1mm
CTR
INTAKE lift - 11.5mm, duration - 243 @ 1mm
Toda A's
Toda B's
Toda C's
Jun Type 1
Jun Type 2
Jun Type 3
Skunk2 cams
Crower 63403
ITR
CTR
And here's the link
https://honda-tech.com/zerothread?id=84317
Someone want to explain to me why you don't need to upgrade valve springs with Jun 2 cams but you do with Jun 3 cams?
www.allmotorhonda.com for the specs. i would upgrade my springs with jun 2 cams. oh wait, i did that already. 12 degree lift is too much for stock springs in my opinoin. the only difference between jun 2 and 3 cams is the 3's exhaust cam has 11.5 degree lift on the exhaust. the 2's dont, the exhaust cam lift is similar to stock itr
[Modified by gsr98vtec, 10:13 PM 7/15/2002]
Hybrid ctr
Nov 22, 2002 10:37 PM
