Classic Hondas All Pre-1988 Hondas.
79 accord distributor pickup coil resistance
Old May 23, 2008 | 09:48 AM
dlmar's Avatar
Default 79 accord distributor pickup coil resistance
I'm trying to repair a distributor off a 79 Accord 1.8L. I've identified that the internal pickup coil is bad, showing zero resistance. I just got a new pickup coil from Autozone that shows 750 ohms, sitting on the bench, not installed in a distributor. I have two other identical assembled distributors, (both good) that each show only 372 ohms, which is almost exactly half the new one's reading. Intuitively, I would think higher is better in this case but I would like to be sure before I put it back together. Does anyone have a Honda spec that tells what the resistance of the internal pickup coil should be? This is at the plug (red and gray wires) coming directly out of the distributor.
Thanks... Don
Old Jun 7, 2008 | 08:17 PM
mrdominotk's Avatar
Default Re: 79 accord distributor pickup coil resistance (dlmar)
Fix your problem?
I need to know the position of the 2-wire (blue and yellow / black). not as they are connected inside the ignition.
I own a honda quintet.
Greetings
http://www.hondaquintet.tk
Sprayteg
Apr 14, 2020 09:20 AM
Dec201
Jun 27, 2017 02:36 PM
Cargame
Sep 25, 2015 09:35 PM
Jeul
Jan 13, 2010 04:12 AM
BoostedH23Accord
Jul 19, 2004 01:54 PM
