LOST POWER AFTER SKUNK2 TB INSTALL....HELP!!!???
Old May 23, 2008 | 07:59 AM
z06eateR's Avatar
Default LOST POWER AFTER SKUNK2 TB INSTALL....HELP!!!???
motor is b16a2...origional in 99 si. ... ok...here it is. the motor has basic stuff, clutch flywheel cai exhaust fpr fuel rail and p28 chipped. this motor was blessed. would just rip through the gears... so i decided to add a little more..and put on a itr intake manifold along with 68mm skunk2 throttle body...
well after doing this install...i drove the car and it felt like it has LOST power..big time at low to mid range...even at top end tho it is lagging! so...i then added 2000 itr cams w/skunk2 cam gears....took the car out...popped vtec loud as hell..but didnt really go anywhere...
so then i took the car and had it tuned on hondata s200...made 167whp...which is good i think...bu tthe car still feels as tho it is lagging through the gears!!! it feels like it made more power and torque with the stock tb, mani, and cams...why is this??? anyone please....
Old May 23, 2008 | 08:03 AM
Eran's Avatar
HT White Ops
Default FV-QR
Are you sure you don't have a massive vacuum leak from the gaskets?
Because the fact that you're making 167 with about 2 grand dumped into the motor is lame.
Old May 23, 2008 | 08:23 AM
z06eateR's Avatar
Default Re: FV-QR (Eran)
i am pretty sure theres no major leaks...wouldn't it be vaccuming if there was a leak???
167 to the wheels on a stock b16 isnt that bad btw...but it should/could be more
Old May 23, 2008 | 08:24 AM
JeffBro's Avatar
Default Re: LOST POWER AFTER SKUNK2 TB INSTALL....HELP!!!??? (z06eateR)
167whp is good for a b16. They don't make a lot of torque to begin with and then with a shitty match up on your manifold ports and too big of a tb your torque curve just fell off. Instead of asking others why don't you try putting the stock tb back on and see if that helps? Post back.
In fact I bet your b16 is making more whp than my untuned jdm gsr.
Old May 23, 2008 | 08:38 AM
z06eateR's Avatar
Default Re: LOST POWER AFTER SKUNK2 TB INSTALL....HELP!!!??? (JeffBro)
so you think its the tb and not the itr manifold??? i was thinking that as well... my torque definately seems to have plummeted since the change. the whp is there...the torque was 109 on the dyno/tune!
also, wuts wierd on the skunks2 tb...it seems like the throttle cable is not able to open the butterfly up all the way..its as though it only opens it 2/3's of the way...
idk...i will try throwing the stock tb onto the itr manifold this weekend and re-post. any other ideas suggestions in the mean time would be great! thnx every 1
Old May 23, 2008 | 09:02 AM
speedooo's Avatar
a stock b16 makes 130-140 MAX on a dyno, 167 is definitely pretty decent. theres a reason why its called the torqueless wonder
Old May 23, 2008 | 09:04 AM
96 EX's Avatar
Default Re: LOST POWER AFTER SKUNK2 TB INSTALL....HELP!!!??? (speedooo)
1.6 liters of displacement =
Old May 23, 2008 | 09:05 AM
z06eateR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo &raquo;</TD></TR><TR><TD CLASS="quote">a stock b16 makes 130-140 MAX on a dyno, 167 is definitely pretty decent. theres a reason why its called the torqueless wonder</TD></TR></TABLE>
yea&gt;.definately..im just sayin..i drive the car everyday..cruise wit my buddies that are runnin h-duece in eg hatch..and gsr in crx...and i would actually keep with them before...now my torque is gone! the whp is there..but i need to bump up some torque b/c even with the hp,...its not really going anywhere..not like it used to at least....
thnx for the props on whp tho.
Old May 23, 2008 | 09:13 AM
kuja396's Avatar
The first thing you need to do is adjust the throttle cable if its not opening all of the way. Have a friend floor the car (with it off obviously) and make sure its opening up all of the way.
Old May 23, 2008 | 09:21 AM
z06eateR's Avatar
Default Re: LOST POWER AFTER SKUNK2 TB INSTALL....HELP!!!??? (kuja396)
yea...we did that. the cable cant be tightened any more. its stretched to the max...any more and its gona hold the butterfly open on the tb. thats whats trippin me out too...idk wtf is goin on with that! i think ima try the stock b16 tb and see what happens..maybe it'll bring some torque back!?!?!?!? if not..idk what ima do!?
Old May 23, 2008 | 09:26 AM
Marauder's Avatar
I think the ITR intake manifold is hurting you more than the TB.
Old May 23, 2008 | 09:32 AM
z06eateR's Avatar
Default Re: LOST POWER AFTER SKUNK2 TB INSTALL....HELP!!!??? (Marauder)
Why would u think that?
Old May 23, 2008 | 10:45 AM
z06eateR's Avatar
BUMP....any other suggestions?? ideas??? comments???
Old May 23, 2008 | 10:50 AM
Eran's Avatar
HT White Ops
Default FV-QR
Comments?
Why does someone who only has 167whp and 109lb/ft have the username 'z06eateR' ... ?
Old May 23, 2008 | 10:55 AM
z06eateR's Avatar
dam..yur a little **** talker huh? that name actually pertains to my 95 dc2 with fully built jdm gsr runnin gt-40r and full race top mount on 26 lbs boost...755whp..
any other **** to talk??
check before it was even built...
http://www.youtube.com and search my dc2 vs type r crx
Old May 23, 2008 | 10:56 AM
speedooo's Avatar
maybe he likes to eat cars
Old May 23, 2008 | 11:05 AM
fryman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Comments?
Why does someone who only has 167whp and 109lb/ft have the username 'z06eateR' ... ?</TD></TR></TABLE>Got to love the hatters.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z06eateR &raquo;</TD></TR><TR><TD CLASS="quote">dam..yur a little **** talker huh? that name actually pertains to my 95 dc2 with fully built jdm gsr runnin gt-40r and full race top mount on 26 lbs boost...755whp..
http://www.youtube.com and search my dc2 vs type r crx </TD></TR></TABLE>
Man my tricycle has more whp than that.
Old May 23, 2008 | 11:08 AM
z06eateR's Avatar
Default Re: FV-QR (fryman)
lol..yup love the haters. i wanna run yur trycycle. lol. ... but for real. i dont want to get off topic of this post..let the haters hate. im just tyrin to get my problem resolved with my si right now..
thnx guys
Old May 23, 2008 | 11:14 AM
Eran's Avatar
HT White Ops
Default FV-QR
Not talking ****, was just curious. Your avatar is of your Si ......... wow, touchy.
And if you've got a 700+ whp car, why can't you figure out why your Si is slow?
Old May 23, 2008 | 11:26 AM
fryman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">if you've got a 700+ whp car, why can't you figure out why your Si is slow?</TD></TR></TABLE>
He's got you there.
Old May 23, 2008 | 11:30 AM
z06eateR's Avatar
lmao...ya got me. lol. u can believe me or not..i dont relaly care. i've never really effed around with n/a motors. im tryin to learn more. i'm going to assume that the larger tb even tho it has itr cams..is what is causing the loss in torque..
but i've always heard more flow along with a good tune will provide results...but it doesnt seem to be the case here....?
Old May 23, 2008 | 11:31 AM
Eran's Avatar
HT White Ops
Default FV-QR
Have you gotten the new setup retuned?
Old May 23, 2008 | 11:37 AM
z06eateR's Avatar
yea yesterday...i put the itr manifold on..with the skunk2 tb..and 2000 itr cams and skunk2 cam gears..1 degree advance on intake. 1 degree retard on exhaust. ...took it yesterday and got tuned on p28 wiht hondata s200...
the whp is there...but the torque is horrible. there was more torque before i did the manifold/tb...for sure. although it wasnt dynoed...i can tell the difference a lot
Old May 23, 2008 | 12:04 PM
lilo_goki's Avatar
ur throttle body is too big for ur all motor set-up, 68mm would be good if ur built, but with just those add-ons, try getting the type r throttle body or some 65mm ones, it'll be better. your type r manifold should help you out more on top end, but if i were you, i would've gotten the skunk2 pro-series manifold instead of the type r manifold.
Old May 23, 2008 | 12:10 PM
z06eateR's Avatar
Default Re: (lilo_goki)
im gona agree with you on the trottle body..but the manifold i disagree. itr manifold actually make better numbers on the dyno that the skunk 2's...
but good advice none the less..
how bout h22 tb..anyone got info on that?
