fuse keeps blowing
Old May 23, 2008 | 06:34 AM
queda's Avatar
Default fuse keeps blowing
ok. so i bought some ebay fog lights. and the switch they came with was broken. so i wired the fogs to the corners. everything was working fine, but then the fuse blew and now it keeps blowing the fuse as soon as i turn on the lights. i checked wires and none are touching. i realy have no idea why the fuse keeps blowing.
thanks for any help
Old May 23, 2008 | 06:46 AM
baller status's Avatar
Default Re: fuse keeps blowing (queda)
Your power circuit has a short or the bulbs themselves are shorted. Get a multimeter and chase it down.
Old May 23, 2008 | 06:49 AM
queda's Avatar
where can i get it?
Old May 23, 2008 | 08:29 AM
insidious-ek9's Avatar
just make sure your bulbs are good, and ur sure there isn't any shorts!
u could probably use an idiot light too.?
Old May 23, 2008 | 08:42 AM
hondabadtoy's Avatar
Default Re: fuse keeps blowing (insidious-ek9)
check all ur wires and make sure u dont have a ground exposed or touching metal. The bulbs could be shorted themselves or ur fuse could be too small to handle all the current, try beefing the fuse to a 30 or so and check ur wiring, if they worked before then sumthing touched or happened after installation, otherwise they would have blown as soon and u turned them on
-Racer X-
Jun 30, 2013 04:56 PM
traxxasx
10
Aug 10, 2009 01:28 PM
BigIslandBoi
Aug 10, 2004 11:41 AM
GSlowR
12
Oct 5, 2002 07:14 PM
