Parts: 94 Integra LS, 91 Integra LS, 93 Prelude SI!!
*90-93 DA Stuff*
-dual A-pillar gauge pods(1 lightly scuffed CF, 1 mint black) $15each
-power steering pump $15
-a/c compressor $15
-tail lights, need to be cleaned, 2 or 3 plugs have been removed $30 for the pair
-1 fender, blue with trim, unsure of side $25
-shift linkages $15each
-shift stabilizer bars $15each
-oem shifters $5each
-dash control switches/buttons $5each
-dark blue door panels, power windows/manual locks, from DA not DB, near mint $30each
-steering column w/ key $75
-under-dash kick panels $10each
-side kick panels $10each
-fuse panel covers $10each
-center consoles $20each
-parking brake consoles $15each
-oil pressure sending unit $15each
-b18a1 cylinder head, complete, unknown milage, looks to be fully functional, came to my shop attached to block with bad main bearings. $100
-92-93 GSR transmission(ys1, cable, non-lsd). Supposedly grinds in 3rd & 5th, was used on b series crx with cut/welded shift linkage. Unsure if a proper fluid change would fix it. Can't go wrong at only ONLY $100!!! *PICKUP ONLY / NO SHIPPING*
*94+ Integra Stuff*
1994 Acura Integra LS 5-speed, silver w/ gray interior, being parted out. THIS VEHICLE WILL BE HAULED TO THE SCRAP YARD IN ABOUT 2 MORE WEEKS, AND I'M NOT SAVING ANYTHING FROM IT...BUY WHAT YOU CAN WHILE IT'S STILL HERE!
**SOLD SO FAR...front seats, rear seats, motor/ecu/linkages/axles/intermediate shaft/harness, gauge cluster, pedal assembly, shifter+****, center console, driver window, doors, side mirrors, hatch, clock, hood, fenders, wheels, armrest/ebrake console, carpet, barebones dash, gas door, a/c lines, a/c compressor, engine mounts, clutch master cylinder, clutch fluid line, windshield wipers, wiper control arms, wiper valance/cover.**
Still plenty of stuff left in and on this car! Plenty of exterior parts, interior parts, engine bay components, hydro trans, etc! Let me know what you're looking for, and I'll let you know if the car has it.
94+ Driver door, light damage, flat baby blue, no window, no mirror. $20
94+ Hatch door, window busted, flat baby blue. $20
94+ After-market tail lights w/ foam gasket, wiring, bulb sockets, mounting hardware, pre-altezza and very nice. $100shipped
*92-96 Prelude Stuff*
h23a1 motor. Around 150k miles last I checked. Bottom end needs rebuilt due to being ran without oil for x amount of time. Head is complete and looks un-damaged. No exhaust manifold, no intake manifold, no knock sensor, no water temp sensors or fan switches, various nuts/bolts/brackets removed for my jdm h22a. $150
h23a1 manual trans. All gears worked fine EXCEPT reverse. Wouldn't go in to reverse at all, almost as if the shifter was being "blocked". Never heard any grinds/noises. Missing speed sensor assembly. $50
Random parts from 92-96 USDM & JDM Prelude-
-jdm h22a fuel rail $10
-usdm h23a distributor & external coil & plug wires $45
-usdm h23a/h22a harness sections and hose brackets $ask
-usdm h23a fuel injectors $20
-jdm p14 ECU(M/T) *$65shipped*
-jdm h22a front coolant housing(plugged sensor/switch hole) $15
Prices DO NOT include shipping unless otherwise noted! Everything sold as-is! No warranties, exchanges, returns or refunds!
I accept PayPal only, and ship via FedEx Ground w/ tracking. Pick-ups are preferred on larger parts due to insane price of shipping.
Modified by socialistic at 2:59 AM 6/17/2008
-a/c compressor $15
*94+ Integra Stuff*
For engine parts, all I really have is OBD-0 stuff. The 94LS parts car is my first one of that generation...so what's on it is all I have for that gen. The motor and ecu are going into my '91, so those parts will be used by me.
ttt
Need this stuff gone! Make offers!
I'm going to load up what doesn't sell into the two wrecked shells I have, and it's all going to get hauled to the scrap yard in 3-4 more days.
Hey I'm interested on that 91 integra cylinder head if you still have it, please e-mail me and so we can get in touch. quikboy1@hotmail.com
classciv
May 13, 2006 07:48 AM
