what is needed to do a valve adjustment?
Old Jul 15, 2002 | 03:04 PM
Mike D's Avatar
Default what is needed to do a valve adjustment?
Bascilly are specialty tools needed, like the one Snap-On makes? And if they arent really needed, do they make the job that much easier it is worth it to buy them?
Any comments welcome...............TIA
Mike D
Old Jul 15, 2002 | 03:10 PM
Spade's Avatar
Default Re: what is needed to do a valve adjustment? (Mike D)
Is this for the D or the B?
Old Jul 15, 2002 | 03:21 PM
Mike D's Avatar
Default Re: what is needed to do a valve adjustment? (Spade)
the engine is a D15, i would like to know about B's too. This is because i will eventually do a swap, so any info helps.
Thanks......Mike D
Old Jul 15, 2002 | 07:55 PM
Mike D's Avatar
Old Jul 15, 2002 | 09:10 PM
ocbeta's Avatar
http://www.c-speedracing.com/howto/v...lveadjust.html
probably similar to a d series, except you just got 1 cam. :D
Old Jul 15, 2002 | 09:42 PM
civicgsr's Avatar
Default Re: what is needed to do a valve adjustment? (ocbeta)
Here's my valve adjustment article. The process will be the same.
Valve adjustment
The difference, is that the rocker arms are not deep within the head. It will be easier and not require any special tools other than the feeler guage.
-Alex
Old Jul 15, 2002 | 10:03 PM
Pengo's Avatar
Default Re: what is needed to do a valve adjustment? (civicgsr)
yea valve adjustment on d series is quite simple. ratchet with sockets for crank pulley bolt and valve cover. small wrench to loosen/tighten bolt on rocker arm thing. flat head screwdriver to adjust. feeler gauge to check clearances. refer to manual for valve lash settings
supersize
Jul 26, 2010 11:50 PM
CivicExMaster
Feb 26, 2008 12:20 PM
eliasromero
Mar 12, 2007 08:37 PM
frontwheelfanatic
Jan 13, 2007 09:54 PM
champLSinteg
Apr 21, 2006 04:45 PM
