How to: JDM Del Sol Plate Fillers on non-JDM Rear Panel
Old May 22, 2008 | 09:28 PM
Fake's Avatar
Default How to: JDM Del Sol Plate Fillers on non-JDM Rear Panel
well i decided to do a how to on these plate fillers...only bc i couldnt find one when i did it either way theres diferents ways you can do it but i decided to do it this way
MOst of yall want the plate fillers on an EDM panel,
but sadly in order to that you would have to cut the
holes on the EDM panel...and thats what i did... Enjoi
<U>Tools:</U>
Dremel
Marker
Safety Glasses (optional)
Gloves (optional)
PATIENCE
PATIENCE
PATIENCE
First remove those 2 button clips as shown and with
a washable marker paint the rim on the circle ( i actually
used a bigger marker)...you wanna go around like 3 times
making sure theres a good amount of paint on it....
Now gently position the filler as how it would fit (if like
you already had the holes) and gently press on it ...
Carefully lift up the plate filler and an imprint of the circle
will remain...
you might wanna do this a couple of times in order to
get the accurate mark
now turn over the plate filler and insert the 2 lil button
clips...now just like before your gonna wanna paint the
tip of them on both making sure theres paint on them..
and Now gently position the filler as how it would fit ..
and press..again should leave an imprint
ONCE YOUR ARE POSTIVE ABOUT YOUR IMPRINTS
MAKE SURE YOU GO OVER IT WITH A PERMANENT
MARKER OTHERWISE IT WILL START TO FADE OF
WHEN YOUR START TO DRILL
Now using your dremel start cuting the imprint
I used the drill bit for my smaller holes
i first made a small hole...then kept making the hole
wider...so until my buttons fit tight (so it wouldnt fall off in the future)
After Both holes are cut should look something like this
Moving on to the Bigger imprint (were the wires we be running)
i did it this way but theres many ways to do it...i started by making an X
and then cut off the edges until it kinda made a square
Once it was squared i used cut off wheel and gently edged
around the circle making it more closer to the lines and more rounder
once completed it looked like this
Now changing tools again with a sanding bit you want to
smoothen the edges up
Or can also do it this way...afterwards your gonna need to use the sanding bit
once you completed that side move on to the next and tadah
your panel is complete
NOTE: your are gonna want to grind the big circle some more
until it actually fits in place....
Be careful while making your imprints try it at least 3 times if not more...
hopefully mine comes out good if not
well thanks for looking
edit: theres is actually 3 lil holes that i did not go over 3
screws should be put to hold the filler in place
or do what i did i made the holes of the button snaps deal
fit tight in there so it would hold in place with out drilling those 3 holes
Modified by Fake at 10:48 PM 5/22/2008
ok so as i was finishing up kinda left some things out
if your wanting to put the 3 lil screws that i was talking about
simply take apart the filler and plave it in the hole and mark
your 3 holes...and drill
ok i had to make holes for my license plates since in EDM
they have those European Plates....so align the license
plates with the rim of the panel
you wanna make sure it centered so go ahead
and measure each side to make sure its equal
make your marks and then drill...
after i did my markings i meausered it and came around
the same size lil before 4 inches on both sides
so begin to drill..be cure not to make the hole to big..
your gonna wanna make it almost the same size as the
bolt that will be going in (in order for it to screw in)
after you get to the size of the bolt ..
bolt the bolt in just so you can make sure its good
and repeat on the other side
ok officially done
here is my finish product:
some pics are still missing.....but im working on it
Old May 23, 2008 | 09:32 PM
Aushonda's Avatar
Default Re: How to: JDM Del Sol Plate Fillers on non-JDM Rear Panel (Fake)
Nice write up
Old Sep 12, 2008 | 04:33 PM
PA MATT's Avatar
Default Re: How to: JDM Del Sol Plate Fillers on non-JDM Rear Panel (Aushonda)
damn, whered the pics go!
Old Sep 12, 2008 | 09:42 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
This is why DIY images should not be hosted on PhotoBucket.
Old Feb 18, 2009 | 09:53 PM
Fake's Avatar
in the process of rehosting
Old Feb 19, 2009 | 09:07 AM
mdrshewrote's Avatar
Sweet sweet sweet!!! Thanks Fake. I'll be checking up on this once it's rehosted!
Old Feb 19, 2009 | 09:11 AM
Hey...Instead of using a dremel, can you use a Nibbler? or is it too thick? I know it will take longer just thought I'd ask.
Old Feb 19, 2009 | 10:59 AM
NOFX's Avatar
H-T White Ops
Default Re: FV-QR
Again!
Old Feb 19, 2009 | 12:50 PM
Mr.Lau's Avatar
nice job
Old Feb 19, 2009 | 01:16 PM
Fake's Avatar
Default Re: FV-QR
i just googled nibbler....and looks like the panel would be to thick...
dremel would cut it faster
Again!
lol tinypic should be good
Old Feb 19, 2009 | 05:21 PM
PA MATT's Avatar
why not use a hole saw?
Old Feb 20, 2009 | 10:10 PM
Fake's Avatar
nibbler ...hole saw....all i know is dremel lol
Old Feb 20, 2009 | 10:49 PM
bluebomber's Avatar
Information Leafblower
I googled Nibbler and this is what I got.
SubSero
Apr 13, 2017 08:01 AM
JarvisW
Feb 28, 2009 01:24 AM
foam
Northwest (Sales)
11
Sep 3, 2007 10:41 PM
EG2Driver
Nov 4, 2005 07:44 PM
