tps problem
Old May 22, 2008 | 06:57 PM
Joeski99Si's Avatar
Default tps problem
installed tb on 99 si ! hooked up scanner and it says that my throttle is 5% open at idle so when i turn the tps to get it to read 0% the holes dont line up ?????
Old May 22, 2008 | 07:08 PM
grog's Avatar
Default Re: tps problem (Joeski99Si)
make sure its installed correctly, theres a metal tab inside that needs to be lined up on the throttle body, or maybe you just need a new tps sensor.
oh and this isnt the right forum for a 99 SI
Old May 22, 2008 | 07:22 PM
Joeski99Si's Avatar
Default Re: tps problem (grog)
f*ck thanx i didnt notice that !
but yeah i will check that
import-tooner
Jul 19, 2013 06:39 AM
jj32jz_EM1
Nov 1, 2011 02:33 PM
scott_turner
13
Apr 3, 2011 02:41 PM
98gsrTEG
Apr 17, 2004 11:12 AM
turbo Si
Jun 10, 2003 07:52 AM
