TB whistles at part throttle
Old May 22, 2008 | 06:49 PM
unsungfate's Avatar
Default TB whistles at part throttle
its kinda annoying... cept when im telling people its my supercharger! lol.
anyways, installed a blox ported IM with the stock TB and it whistles now. any reasons why? something i did wrong or is it the TB too small for IM...
Old May 22, 2008 | 07:39 PM
unsungfate's Avatar
Default Re: TB whistles at part throttle (unsungfate)
bump?
Old May 22, 2008 | 07:49 PM
starion88esir's Avatar
The whistling is most likely indicative of an air leak. With the car idling spray around (not into) the TB and see if the rpms increase and the whistling is made.
Old May 22, 2008 | 09:50 PM
994door's Avatar
Default Re: TB whistles at part throttle (starion88esir)
mine does it too, even more when i switched to a skunk2 mani. never thought about it though.
Old May 23, 2008 | 01:53 AM
pimpvw's Avatar
Default Re: TB whistles at part throttle (994door)
you got a leak somewere
Old May 23, 2008 | 05:45 AM
EG2Driver's Avatar
Default Re: TB whistles at part throttle (pimpvw)
if its not through the whole powerband, you are fine. My B16 did that at around 3500 with a particular throttle position. I kinda liked it!
Old May 23, 2008 | 08:35 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
It's 100% normal. Anyone who says it's a leak has never put an aftermarket manifold on a B16. Mine whistled loud enough to wake the dead.
Stock manifolds do it too...just not as loud. Lots of Hondas whistle.
My Stock JDM b16a whistled. Then it whistled louder with the skunk2 IM. My GSR whistled with the stock IM and with a skunk2 IM. My friend's Y8 whistles with a stock IM. My D16Z6 from back in the day whistled with a stock IM. My S2000 whistles with a stock IM. My EM1 whistles with a stock IM.....see the pattern?
If you dont like hearing it, put the stock intake back on. That will shut it up.
Old May 23, 2008 | 08:59 AM
Jonny G.'s Avatar
i had the same problem and happened to fix it less than a week ago. i was running a skunk2 IM with stock TB and it whistled like crazy. the fix? bought a 68mm Omni Power TB, now the whistle is gone! try that
Old May 23, 2008 | 01:00 PM
unsungfate's Avatar
Default Re: TB whistles at part throttle (Jonny G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny G. &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem and happened to fix it less than a week ago. i was running a skunk2 IM with stock TB and it whistled like crazy. the fix? bought a 68mm Omni Power TB, now the whistle is gone! try that </TD></TR></TABLE>
well if ima fix it that way... might as well get a 72mm TB which was my plan from the get go... hence the ported IM
Old May 23, 2008 | 06:18 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unsungfate &raquo;</TD></TR><TR><TD CLASS="quote">
well if ima fix it that way... might as well get a 72mm TB which was my plan from the get go... hence the ported IM</TD></TR></TABLE>
Why the F would you want that much airflow? What else is done to those engines?
Old May 24, 2008 | 06:15 PM
unsungfate's Avatar
Default Re: TB whistles at part throttle (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
Why the F would you want that much airflow? What else is done to those engines?</TD></TR></TABLE>
why the F would i want that much air flow?? well im building my head for a b20 vtec that (in my thoughts) will be off the effing hook..
Old May 24, 2008 | 06:29 PM
J98EX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">It's 100% normal. Anyone who says it's a leak has never put an aftermarket manifold on a B16. Mine whistled loud enough to wake the dead.
If you dont like hearing it, put the stock intake back on. That will shut it up. </TD></TR></TABLE>
True. Every Honda I have ever owned whistled
Old May 24, 2008 | 07:55 PM
.Ej8 yaahh's Avatar
Default Re: TB whistles at part throttle (J98EX)
perfectly normal.. Mine does it too, at a certain RPM and partial throttle.
dc4teg95
Dec 8, 2006 08:08 AM
asefi944
Apr 11, 2005 09:43 PM
PearlCrx
Dec 20, 2003 12:41 PM
shotty527
Nov 7, 2003 12:18 PM
xsnrgsr
10
Aug 20, 2003 01:12 PM
