Honda S2000 Honda S2000
Clanking noise from rear end, only happens over bumps
Old May 22, 2008 | 03:24 PM
yuning83's Avatar
Default Clanking noise from rear end, only happens over bumps
Hello, got the metal clanking noise from back of the car whenever going over bumps. Gets worse as you drive it. Any ideas?
Old May 22, 2008 | 03:38 PM
as2001s2k's Avatar
Default Re: Clanking noise from rear end, only happens over bumps (yuning83)
dose it sound like a axle claking
Old May 22, 2008 | 03:59 PM
yuning83's Avatar
Default Re: Clanking noise from rear end, only happens over bumps (as2001s2k)
I don't know what axle claking sound like.
Old May 22, 2008 | 04:12 PM
as2001s2k's Avatar
that what it sound like to me what year is it and how many miles
Old May 22, 2008 | 04:14 PM
yuning83's Avatar
2000 s2000 lol it rythms with 57k miles
Old May 22, 2008 | 04:22 PM
Black S2K's Avatar
your rear might be going bad.
mine clicks when im engagingthe clutch in 1st or reverse
Old May 22, 2008 | 04:59 PM
HondaKyle's Avatar
Default Re: (Black S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">your rear might be going bad.
mine clicks when im engagingthe clutch in 1st or reverse </TD></TR></TABLE> Mine was doing the same thing! It doesnt make the sound any more so Ill pretend it fixed it self!
Old May 22, 2008 | 05:14 PM
yuning83's Avatar
Default Re: (HondaKyle)
it doesn't click, and it's not when shifting. You'll hear it only when going over bumps.
Old May 22, 2008 | 05:16 PM
HondaKyle's Avatar
Default Re: (yuning83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yuning83 &raquo;</TD></TR><TR><TD CLASS="quote">it doesn't click, and it's not when shifting. You'll hear it only when going over bumps. </TD></TR></TABLE> put your car on a lift or jack it up and lift up on the wheels and see if it makes the sound. It should be easer to find out what is making the sound...
Old May 22, 2008 | 06:22 PM
yuning83's Avatar
I tried that already, couldn't reproduce the noise in my garage
Old May 22, 2008 | 07:12 PM
joey1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yuning83 &raquo;</TD></TR><TR><TD CLASS="quote">Hello, got the metal clanking noise from back of the car whenever going over bumps. Gets worse as you drive it. Any ideas?</TD></TR></TABLE>
check your swaybar nushings and swaylinks, they may be worn out.
i have a clanking noixe but it happens when driving the car in reverse and stoping, right as you are stoping it makes the noise. i don't wanna mess with it so i'll let the warranty take care of it
Old May 22, 2008 | 07:22 PM
yuning83's Avatar
Default Re: Clanking noise from rear end, only happens over bumps (joey1320)
no it wasn't the sway. First thing I thought was something loose down here, but the sway and the struct bar are all tight and nothing is loose... I have searched a bit, ppl say something about cv joint, and I'm pretty sure it's not the wheel bearing because it will make whooshing sound just by moving.
Old May 22, 2008 | 10:44 PM
yuning83's Avatar
After searching a bit more, I'm narrowing it down to the ball joint. Anyone had that replaced before?
here is a pretty useful link too
http://www.popularmechanics.co....html
Old May 23, 2008 | 07:48 AM
yuning83's Avatar
Ok just let you know all what happened. The mechanic found that my rear caliper bolts are missing. Must of been loose and poped off while the car is moving. Make sure you all check that if you work on your own brakes and ended up with the same problem. I'm paying 105 bucks just to have them check it and it will cost me 105 bucks to replace them stupid bolts... I could of done that myself for free... well lesson learned. Hope someone find this post useful to fix their own clanking noise...
stinkfist2000
Honda S2000
17
Apr 15, 2008 02:05 PM
ZipTieGUy
Mar 8, 2006 10:24 PM
Los.
Mar 2, 2005 10:01 AM
Pompiuses
Oct 13, 2004 02:59 PM
shipsaeki
May 28, 2003 07:13 PM
