Fixed my popping suspension!!! Could be your problem too (camber kit)
Camber Kit bolts came loose!!!
My car recently developed a bad clicking popping sound coming from my right front suspension. It happened when I hit the brakes, turned the corner and hit the gas. It began to get worse and worse. I checked all of the bolts on the struts, x-member, tie rods, and even motor mounts. Nothing was loose!!!
I finally found it!!!
I am running an adjustible front camber kit and one of the bolts vibrated loose. The whole wheels and suspension was moving from + to - camber and I could never figure it out. I thought that I would share this with some of you as I have seen quit a few post of people with similar problems.
I had these professionally adjusted by a lign-up shop just 6 months ago so I had no reason to suspect them as being loose
Hope this can help fix some of your cars if your running a similar setup
