BLOW OFF VALVE question
Old May 22, 2008 | 12:13 PM
accord99power's Avatar
Default BLOW OFF VALVE question
My greddy type S has to vacuum ports which one do i connect to a vacuum source or do i do both of them?
also i know i should put a breather on the valve cover hose, but is it ok to run a hose back into the intake on a turbo setup?
Old May 22, 2008 | 12:18 PM
sweetfwdthunder's Avatar
Default Re: BLOW OFF VALVE question (accord99power)
You probably shouldn't run that hose to the intake unless you have future plans of pressurizing your breathing system and burning oil
Old May 22, 2008 | 12:40 PM
integraturbo's Avatar
use the one right on top of the blow off valve
Old May 22, 2008 | 01:01 PM
Default Re: (integraturbo)
that was quick thanks for the info guys! that completed my research on my turbo setup. i just got the intercooler piping ran, just waiting for sunday to install everything else.
Old May 22, 2008 | 01:08 PM
1fastlude1's Avatar
Default Re: (accord99power)
do not run the breather hose to the intake unless you want the engine running off blowby, and ive never seen charge pipeing with a port for a breather hose
Old May 22, 2008 | 09:20 PM
Default Re: (1fastlude1)
i know im using a cold air intake as piping on the one side so i will have a port but il just cap it off.
Old May 25, 2008 | 06:17 AM
dozier's Avatar
the top one
DannyDeuce
Sep 8, 2006 03:46 PM
B16Civic93
Feb 26, 2005 01:01 PM
Tad
Nov 1, 2004 12:06 PM
DCStreetHtch
Feb 27, 2003 05:59 PM
_Endless_
Aug 27, 2002 03:03 PM
