obd0 b16 alternator?
Old May 22, 2008 | 10:39 AM
JDM-Punk's Avatar
Default obd0 b16 alternator?
i have a obd0 b16 in my 90 teg and it needs a new alternator, should i get one for a 95 vtec sol (b16a3) or will that not work?
and yes i did search
Old May 23, 2008 | 09:43 AM
allmotorek8's Avatar
Default Re: obd0 b16 alternator? (JDM-Punk)
from what i heard there all the same for b series but i would double check and does anyone wanna chime in on that
Old May 23, 2008 | 09:55 AM
inspiration's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-Punk &raquo;</TD></TR><TR><TD CLASS="quote">i have a obd0 b16 in my 90 teg and it needs a new alternator, should i get one for a 95 vtec sol (b16a3) or will that not work?
and yes i did search </TD></TR></TABLE>
You should get one from the 90 Integra. Instead of the B16A from a Del Sol. The connection plug might be different.
Old May 23, 2008 | 04:14 PM
JDM-Punk's Avatar
they both ended up being the same, but the one for the del sol was a 80 amp and had a tad bit bigger casing, while the teg one was only a 70 amp, and had the same exact casing so i just used that
crexer
Jul 17, 2022 06:34 PM
B16ef8
Jan 27, 2003 12:53 PM
RCautoworks
Jan 15, 2003 05:55 PM
Shea-bird
Oct 22, 2002 02:08 PM
E-lude78
Aug 15, 2002 05:52 PM
