e85 injection injector size.....searched & still searching
whats up? i'm planning for 300 whp or maybe even 325 ish. i have 450cc dsm injectors and will also be running methanol injection. Snow performance with the green nozzle i believe. 300-350 horse. i know the injector size calculation, but not with the methanol injection...injection will be before the throttle body in the intake charge piping.
Thank You.
Modified by 95dxsir2 at 12:27 PM 5/22/2008
Thank You.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">are you talking about e85 or methanol?</TD></TR></TABLE>
That would be nice to know
sorry guys, i meant methanol, i was getting brain [freak]ed @ the moment
what would you guys recommend...e85 or methanol injected through the pipe?
Modified by 95dxsir2 at 12:33 PM 5/22/2008
For some reason I thought it was a little richer than ethanol. I've seen a chart before regarding widebands, but I just can't remember where...sorry.
Edit: found it. http://www.smokemup.com/tech/fuels.php
According to that, the injectors should be ~2.46 larger to maintain the same stoimetric value as gasoline. Since it shows meth produces ~27% more power for the same amount of air, that means 1000cc injectors would probably be needed to make 350whp (100% duty cycle). I'd get 1200cc or 1600cc injectors minimum...
Modified by HiProfile at 2:45 PM 5/22/2008
are u serious, 1200 to 1600cc
even with the injection going into the intake manifold seperate from the fuel injectors?
On an H22 I ran 700cc injectors with Methanol injection at the throttle body. Made about 320whp @ 10 psi with a GT30. Still had lots of room left on duty cycle.
460whp @ 17psi and still not maxed out.
Bringing this back from the dead. I have a built D16 with 800cc injectors and made 308whp on 93 octane conservatively tuned. If I were to switch to e85, would 800cc injectors carry me very much further?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT »</TD></TR><TR><TD CLASS="quote">Bringing this back from the dead. I have a built D16 with 800cc injectors and made 308whp on 93 octane conservatively tuned. If I were to switch to e85, would 800cc injectors carry me very much further?</TD></TR></TABLE>
They would support roughly as much power as 550's would on gasoline. I'm at ~320whp with 880's on corn juice and I have plenty of room to crank the boost up.
awesome, glad to hear. I have 880's haha. I mistyped when I said 800cc, but I'm sure you assumed that much. Would it really be worth it for me? From what I calculated, these should be good to about 372 assuming they will do 70% what they would on gasoline
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullblown »</TD></TR><TR><TD CLASS="quote">Weve done quite a few cars on E85 and heres what we found on our dyno.
Single Walbro + 1000cc = 420-430hp
Dual Walbro + 1000cc = 520-530hp
Dual walbro + 1600cc = 630-640hp</TD></TR></TABLE>
Good info. Looks like I need to swap to a dual walbro setup soon.
