Sounds like my car is bogging out....HELP!
Old May 22, 2008 | 08:46 AM
jkinros's Avatar
Default Sounds like my car is bogging out....HELP!
What would cause a car to bogg out around 3500+ rpms? When at low rpms it seems like its running fine, but when i step on the gas after 3500 it just makes a lot of noise but no pull?!?! What do you guys think it is. I'm guessing that my cat converter is starting to get plugged. I don't think its the spark plugs or wires. The exhaust fumes are bad, like not burning all the fuel or running very rich. I have a stock 99hatch, which direction should I go with this?
THANKS for your help
Modified by jkinros at 2:43 PM 5/22/2008
Old May 22, 2008 | 01:44 PM
jkinros's Avatar
Default Re: Sounds like my car is bogging out....HELP! (jkinros)
ANYONE.....???
Old May 22, 2008 | 02:46 PM
swiss217's Avatar
you might have water in the engin take it up real slow in 1st and take it up to like 6 or 7 and hold it there for like a min. it should clear any thing out that is in there. that is how i fixed my eg i had the same problem. either that or some how your ecu went into safe mode
Old May 22, 2008 | 03:35 PM
jkinros's Avatar
Default Re: Sounds like my car is bogging out....HELP! (swiss217)
So how does one get water in their engine?
Old May 22, 2008 | 03:38 PM
jkinros's Avatar
if ecu went into safemode, how do i put it back to regular mode?
Old May 23, 2008 | 02:56 PM
jkinros's Avatar
Old May 23, 2008 | 03:52 PM
boostlesseg's Avatar
i had the same question, but my EG runs like crap til 4000 rpm's... same problem??
Old May 23, 2008 | 09:56 PM
dr.garagetuner's Avatar
have you checked it to see if the timing is correct.
egvtec
Jan 7, 2010 07:43 PM
Xtream_V
Mar 9, 2007 09:50 AM
Discontained
10
Jan 7, 2007 10:36 AM
crx_88_si
Dec 8, 2005 05:24 AM
