Help a Newb! B16 cable box LSD to fit in B18 hydraulic box
Guys,
Is it possible to fit back a Cusco 1.5 way LSD from a B16 Cable gearbox into a GSR Hydraulic gearbox
? Any help much appreciated!
From: gravity rides everything...everything will fall, se GA/ne FL
yeah. direct swap. utilize a b16 4.40 (66 tooth) ring for the diff.
*may have to trim some of the casing if it doesn't spin when you set in.
