Maint. Required
I did a search I didnt find anything, I hope I dont need my flame retardent suit. My light is on how do I turn it off. Im pretty sure I heard there are certain fuses you can take out to turn it off. My maintence is up to date but the dealer is way too expensive.
I believe this is the correct way to do it:
1. Turn the key to the I or II position.
2. There is going to be a blue button under the stearing wheel. To find it align your finger with the right side of the brake pedel and it should be there. Once you find it push it.
IM me if you have troubles.
easy enough, with the key in the on position (car can be running, it doesn't matter), there is a button on the underside of the dash on the driver side. basically, from the normal sitting position, lean forward and with your right hand, feel under the dash for a box and when you find it, press and hold the button with your middle finger for about 3 seconds til the light shuts off. kinda hard to explain but its simple when you find it. hope that helps
. My explanation is easier.
kcannaday
Feb 27, 2005 08:28 PM
