EG airbag question?
Old May 21, 2008 | 11:12 PM
EvoMperor's Avatar
Default EG airbag question?
I have a 95 eg and with driver and passenger side airbags.
my question is if I replace the steering wheel with a non-srs and if I get in an accident, will the passenger side airbag still deploy? or will it not work anymore? I really want to get a steering wheel with a quick release hub, but I don't want to put the lives of any passenger in my car in danger. thanks in advanced
Old May 22, 2008 | 12:14 AM
BlueIntegraBoy's Avatar
Default Re: EG airbag question? (EvoMperor)
Do an airbag mod.
https://honda-tech.com/zerothread?id=1790119
Old May 22, 2008 | 12:28 AM
EvoMperor's Avatar
has this been proven to make the passenger side airbag still work? and will those pictures still apply to a civic seeing as how that writeup is for a prelude? thanks
Old May 22, 2008 | 12:29 AM
Default Re: (EvoMperor)
Yes, you need a 2.2 ohm resistor. Connect the two ends into the driver airbag plug on the steering column. The SRS computer will think there's an airbag there and the passenger airbag will still function.
Old May 22, 2008 | 12:33 AM
EvoMperor's Avatar
will the mes plug in the picture be in the same position on an eg? and will I have to make a conductor and follow the same steps as in the prelude write up? or is there a separate mes plug for the passenger side? thanks again for your help.
Old May 22, 2008 | 12:43 AM
MES connector is located on your fusebox (plugged into the fusebox).
Old May 22, 2008 | 01:17 AM
EvoMperor's Avatar
the fusebox in the cabin? and is it plugged in behind the box(what does the mes look like)? also will I have to follow the procedure like in the prelude write up with the conductor? thanks for you help man! I noticed ure from hilo? R u rooting for BJ Penn in the fight this weekend? I'm into bjj and hes one of my favorite fighters, so I hope he whoops sherks ***!, thanks again man
300whpej
Nov 10, 2009 01:49 PM
dohcdelsol
May 1, 2008 05:41 AM
743power
Mar 10, 2003 10:09 AM
