sohc vtec vs non vtec...
Old May 21, 2008 | 09:12 PM
pat91hb's Avatar
Default sohc vtec vs non vtec...
i am planning on making my 91 civic si as fast as it can go...money not an issue but not going b series...should i keep the a6 and get a cam/headwork/ and turbo the **** outta it (holset boosted around 25psi)....or go with a mini-me......would getting a vtec head benefit me any with my goal? trying to get in low 11's
Old May 21, 2008 | 09:16 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: sohc vtec vs non vtec... (pat91hb)
hmm.... VVT, and a better head vs a normal single cam setup with a lesser flowing head stock for stock.
I'm [freak]ing stumped.
Old May 21, 2008 | 09:29 PM
pat91hb's Avatar
Default Re: sohc vtec vs non vtec... (***$nyper)
i can do my own machine work...im taking a engine maching course now so thats no prob....just hear vtecs uneccesary if you got a boost that big am i rite???!?!
Old May 21, 2008 | 09:39 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pat91hb &raquo;</TD></TR><TR><TD CLASS="quote">i can do my own machine work...im taking a engine maching course now so thats no prob....just hear vtecs uneccesary if you got a boost that big am i rite???!?!</TD></TR></TABLE> No you arn't correct at all.
Also even if you didn't have VVT the castings and flow of the vtec heads is better stock for stock flat out.
Old May 22, 2008 | 06:10 AM
pat91hb's Avatar
alrite thanks
Old May 22, 2008 | 08:31 AM
mike-y's Avatar
well, a turbo setup capable of running 11s is going to cost WAY more than a vtec head swap. And just a vtec head swap isn't going to get you anywhere close to your goal of 11s, so I don't understand why you are trying to choose one over the other - its apples and oranges.
vtec head + turbo system sounds good to me. For what you want to do (run 11s), you'll need a decent engine build anyways (at least if you wanted it to last). Make sure you check out the boost forum for more info on turbo components and engine builds. Its a lot easier to follow a plan that you know has worked for other people, than trying to figure it all out on your own.
Old May 23, 2008 | 06:56 AM
pat91hb's Avatar
Default Re: sohc vtec vs non vtec... (mike-y)
well i was going th holset/vitara route which actually will cost me under 1.5 grand tuned...i can do my own tuning and stuff. theres some other dude who did this with my car/ setup and got the results i want!
O16581724 5 2 5
Nov 6, 2005 09:26 PM
itsmebeaner1987
Oct 17, 2004 07:30 AM
igo4bmx
Jun 30, 2004 12:27 PM
davken1102
Aug 20, 2003 07:24 AM
GroundZer0 336
Jul 27, 2003 01:44 PM
