help identifying my sohc head
i want to know what kinda head i got...its currently on a d15b8 enigine....with a sohc vtec head on it is there numbers or anything anywhere so i can identify if its a obd1 or obd2? need this info to see if my ecu/jumper will work with it
Modified by pat91hb at 10:49 PM 5/21/2008
whether the head is OBD1 or OBD2 doesn't affect your ECU jumper - it only affects which distributor will bolt onto it - OBD1 head, use OBD1 distributor - OBD2 head, use OBD2 distributor and get distributor jumper from Rywire to connect the harness connector to the OBD2 distributor connector
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pat91hb »</TD></TR><TR><TD CLASS="quote">actually i just found a p08-2???</TD></TR></TABLE>P08-2 is OBD1 D16Z6 head
