Correct part number for rear pads?
I purchased the OEM rear brake pad set based on the part number found several of the EPC sites (acuraoemparts, etc). They all come up with 43022-S84-A50 for the 01 ITR. Got em, look good, but just slightly too long to fit in the caliper. Does anyone know the correct p/n?
Using the online EPC hasn't failed me before, but I now note this p/n seems to match that for the accord. I hope Honda hasn't discontinued our "special" itr pads.
Thanks- no luck searching or in the FAQ.
ITR rear pads are the same as 92-96 Prelude VTEC pads, which is the part number you listed:
43022-S84-A50 PAD SET, RR.
I've checked other online EPCs and the part number is the same as above.
Andrew Solomon
Dec 30, 2014 11:21 AM
TodaSi
Oct 2, 2002 05:37 PM
