Need a good degreaser with certain qualities.
Old May 21, 2008 | 03:58 PM
TurboEM1's Avatar
Default Need a good degreaser with certain qualities.
Hey guys I am looking for a good degreaser. Here is what I am trying to find. Hopefully it can be done.
- Needs to clean off oil, old lubricants, dirt and other grit.
- Something that doesn't have to be rinsed with water. It will just dry and leave no residue behind, just clean plain metal. Faster drying is better too.
- Wiping it down or scrubbing is no problem.
- Its always a plus if it is safer on paint and other things.
If it matters here are what the pieces are made of. A zinc-alloy plated chain, a nickel plated steel sprocket, and an anodized aluminum sprocket.
Would kerosene be good? Acetone? Paint thinner/Mineral spirits?
What would you recomend? Thanks
Modified by TurboEM1 at 9:02 PM 5/21/2008
Old May 21, 2008 | 04:16 PM
chimmike's Avatar
Default Re: Need a good degreaser with certain qualities. (TurboEM1)
you're still gonna need to wipe the items down if you don't plan on hosing 'em off.
Acetone will work.......brake cleaner perhaps?
Modified by chimmike at 8:54 PM 5/21/2008
Old May 21, 2008 | 04:17 PM
Dazed and Confused's Avatar
brake cleaner
Old May 21, 2008 | 05:02 PM
TurboEM1's Avatar
Default Re: Need a good degreaser with certain qualities. (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">you're still gonna need to wipe the items down if you don't plan on hosing 'em off.
Yea wiping them down is no problem at all. Even if it needs to be scrubbed thats fine. I just really want it all to evaporate as my main priority.
Old May 21, 2008 | 08:09 PM
90blackcrx's Avatar
Default Re: Need a good degreaser with certain qualities. (Dazed and Confused)
Just be careful if you are welding it, brake cleaner can burn off and leave nasty fumes.
Old May 22, 2008 | 04:11 AM
TurboEM1's Avatar
Default Re: Need a good degreaser with certain qualities. (90blackcrx)
its actually to degrease chains and sprockets on some machines before they get relubed.
Old May 22, 2008 | 04:58 AM
xxbulaxx's Avatar
Use brake cleaner then...
big_poppa49
Paint and Body
13
Dec 30, 2007 07:38 PM
dohc_profile
May 3, 2006 06:12 PM
lowRIDAH
May 13, 2005 08:22 AM
Dc2 Powered
Mar 9, 2004 11:51 PM
sporkcrx
Oct 9, 2002 07:32 AM
