Timing belt broke while driving
Old May 21, 2008 | 02:32 PM
Mark D. Surface's Avatar
Default Timing belt broke while driving
Hey guys. My neighbor has a dilema. While driving his timing belt broke. Could anything internally be broke as well?
Old May 21, 2008 | 02:55 PM
Padawan's Avatar
Darth ModerVader
Default Re: Timing belt broke while driving (Mark D. Surface)
What kind of car? If it's an interference engine (like most Hondas), there is a good chance that there was internal damage. Advise him not to try to start the car until the damage is assessed and repaired. Hopefully he got lucky and no permanent harm was done.
Old May 21, 2008 | 03:37 PM
Default Re: Timing belt broke while driving (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">What kind of car? If it's an interference engine (like most Hondas), there is a good chance that there was internal damage. Advise him not to try to start the car until the damage is assessed and repaired. Hopefully he got lucky and no permanent harm was done. </TD></TR></TABLE>
Its a 94 Civic EX (D16Z6). I didnt think that older engines weren't interference engines. Im guessing the whole valvetrain is bent up?
Old May 21, 2008 | 03:41 PM
EG2Driver's Avatar
tell him to do a leakdown test so you don't need to rotate the engine by using the starter. It'll tell him if his valves are bent.
Old May 21, 2008 | 04:02 PM
Default Re: Timing belt broke while driving (EG2Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2Driver &raquo;</TD></TR><TR><TD CLASS="quote">tell him to do a leakdown test so you don't need to rotate the engine by using the starter. It'll tell him if his valves are bent.</TD></TR></TABLE>
Sounds good. I haven't done one of these in years.
Can you visually see if the valves are bent?
Old May 21, 2008 | 04:07 PM
EG2Driver's Avatar
you can see it if the head is off the car using a feeler gauge i presume? Im not sure. You should look for impact spots on the pistons, thats going to be easier to see than the valves themselves.
Old May 21, 2008 | 04:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2Driver &raquo;</TD></TR><TR><TD CLASS="quote">you can see it if the head is off the car using a feeler gauge i presume? Im not sure. You should look for impact spots on the pistons, thats going to be easier to see than the valves themselves.</TD></TR></TABLE>
Thanks much. Much appreciated everyone!
jus2sho
67
Sep 6, 2006 06:17 PM
Metalluthier
15
Jul 17, 2006 05:12 PM
mingbling96
Sep 12, 2005 09:50 PM
s8an
Aug 6, 2004 11:16 PM
Sephro
Sep 30, 2002 06:50 PM
