Turbo 18c1 Civic Wont start!?! Need help
Old May 21, 2008 | 12:07 PM
jordan_civic's Avatar
Default Turbo 18c1 Civic Wont start!?! Need help
It started earlier but was dying at stop signs and bogging while drive. Now I parked it and it wont start.
Any ideas?
Thanks
Old May 21, 2008 | 12:11 PM
chimmike's Avatar
Default Re: Turbo 18c1 Civic Wont start!?! Need help (jordan_civic)
I don't think you needed to post this in the 92-2000 civic section.
anyways: dead battery? Bad alternator/battery connection?
vac leak? fuel pump issue?
Old May 21, 2008 | 12:15 PM
Default Re: Turbo 18c1 Civic Wont start!?! Need help (chimmike)
I dont know. It was running fine yesterday and today its dying all the time. I dont think its battery cause the cd player is running fine. Would a stock fuel pump trying to run a 340hp turbo be a problem. I am not for sure if a walbro was put in or not.
Old May 21, 2008 | 12:53 PM
OMG B16's Avatar
Is your car tuned?
Old May 21, 2008 | 01:43 PM
Default Re: (OMG B16)
Yeah its tuned. Well its supposed to be.
Old May 21, 2008 | 02:25 PM
boostedgsr1234's Avatar
Default Re: (jordan_civic)
1) check timing
2) spark/ ignition
3) fuel pressure
4) tune
5) vac. leak
GL
Old Feb 23, 2009 | 12:54 PM
piko09's Avatar
New User
your car is an peace of **** period
Old Feb 23, 2009 | 02:38 PM
Mrbustanut's Avatar
Nice first post. Hope you had a pleasant stay.
Old Feb 23, 2009 | 02:45 PM
94 TuRbO dC2's Avatar
Banned
not something you wanna be iffy about... literally the longevity and the life of your motor ride on that and that alone.
if your not sure if its been tuned or your not sure if the car has a walbro... find out.. check to see if it has a walbro and hook up a wideband and you should be able to to tell fairly easily just by the reading on the wideband weather the car has been tuned or not from my understanding.
Old Feb 23, 2009 | 07:15 PM
HiProfile's Avatar
Was it running before with ZERO changes? How long ago? Did you buy all the parts & ecu, install them, and have the issues? I'd bet on the later, since a stock civic pump will never keep up with 340whp. It will start it up fine, but fizzle once you get past 200whp. Its a 79lph pump not rated for high pressure.
See if its getting spark, then see if the injectors are squiring fuel. I was going crazy last week diagnosing a similar issue - cleaning the injectors' inlets helped produce some droplets, but...I forgot to change the MAP sensor setting from 2.5bar to stock (MAP was replaced recently). The default fuelcut of 3psi was active, and with a STOCK MAP voltage it thought it was running 6.2psi... The moral is cross every I and dot every T, no matter how obvious
Steveramirez21
May 11, 2013 09:40 AM
JDM Freakk
Jun 21, 2011 05:36 PM
k_vd16
Feb 5, 2011 01:42 PM
H22Ej1
Nov 27, 2006 12:10 PM
bQQsted hybrid
Jun 16, 2003 04:44 AM
