Front Crossmember Bushings. Are they worth replacing/upgrading (polyurethane)
Old May 21, 2008 | 11:20 AM
gringo7718's Avatar
Default Front Crossmember Bushings. Are they worth replacing/upgrading (polyurethane)
I just wanted to know if it was worth replacing the radius arm bushings with polyurethane bushings? thanks
If so, are there any other companies available other than the 50$ innovative ones?
(Energy suspension does not produce these bushings for our cars)
http://www.innovativemounts.co...59103
Modified by gringo7718 at 8:30 PM 5/21/2008
Old May 21, 2008 | 11:35 AM
blaak-crx's Avatar
Default Re: Front Crossmember Bushings. Are they worth replacing/upgrading (gringo7718)
How about Prothane? This is what I have on my Crx.
Old May 21, 2008 | 12:10 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
I have energy suspension ones that i'll sell you for $5 + a pick up tag.
Old May 21, 2008 | 12:17 PM
Malgerus's Avatar
Default Re: (ComeOnKip)
Yes. They really stiffened up my front end at the track. Eliminated my minor wheelhop issues and made my car more consistent. They were also about $5 for both, and they took 20 minutes to install, so definitely worth it.
Old May 21, 2008 | 12:37 PM
gringo7718's Avatar
Default Re: (Malgerus)
Anyone have a part# or a link to where someone could purchase one?
the prothane website is like pulling teeth
Old May 21, 2008 | 01:16 PM
Malgerus's Avatar
Default Re: (gringo7718)
ES DO make the bushings... can't recall the part number, and I don't think I have the box anymore.
Old May 21, 2008 | 02:00 PM
gringo7718's Avatar
when I called them directly, the condescending individual I spoke with said they do not offer any bushings not listed here. please let me know if you see them
http://www.energysuspension.com/pages/hon1.html
Malgerus's Avatar
well, seems that I made a note of the PN a few years ago in my profile:
pn# 167102
Old May 21, 2008 | 02:07 PM
gringo7718's Avatar
alright so... if my reading comprehension isnt too flawed,
the energy suspension website calls these bushings "Front Strut Rod Bushing Set"
part# 16.7102
thanks very much! here is a website for future use
http://www.energysuspensionpar...E7102
Old May 21, 2008 | 04:11 PM
Crx Jimmy's Avatar
progress also makes a set of spherical bearings that eliminate all play. and still move smoothly. I think heel toe auto sells them, turns your stock crossmember into a traction bar
Old May 21, 2008 | 08:07 PM
welfarepc's Avatar
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">progress also makes a set of spherical bearings that eliminate all play. and still move smoothly. I think heel toe auto sells them, turns your stock crossmember into a traction bar </TD></TR></TABLE>
got a link? i was thinking to weld a plate over the stock bushing hole and do a heim joint but this sound easier.
Old May 21, 2008 | 09:33 PM
gringo7718's Avatar
Default Re: (welfarepc)
http://progressauto.com/store/index.php?cPath=59
Modified by gringo7718 at 6:55 AM 5/22/2008
Old May 22, 2008 | 05:20 AM
WWDTrackRacer's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringo7718 &raquo;</TD></TR><TR><TD CLASS="quote">I just wanted to know if it was worth replacing the radius arm bushings with polyurethane bushings? thanks</TD></TR></TABLE>
I started off with ES and yes, they are a good upgrade over stock. My friend uses the Progress bearings, lots of drilling to install. Works great. I'm running a FullRace setup now, much nicer. but $$$.
Old May 22, 2008 | 06:23 AM
Red_ED8's Avatar
Default Re: Front Crossmember Bushings. Are they worth replacing/upgrading (WWDTrackRacer)
Any idea as far as in what order those spherical bearings go in? It's a 3 piece assembly (plate, bearing housing, plate) but I'm not sure if the bearing housing goes in the front of the x-member or in the rear? Quick example: stock assem is plate, bushing, x-member, bushing, backing plate.
Old May 22, 2008 | 08:07 AM
BumbleBee Tuna's Avatar
dang! that looks sick! im pretty sure ima pick these up! i got the innovativ xmember, cant wait to try those out! im due for replacement! thanks for postin!
Old May 22, 2008 | 08:12 AM
welfarepc's Avatar
Default Re: Front Crossmember Bushings. Are they worth replacing/upgrading (Red_ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">Any idea as far as in what order those spherical bearings go in? It's a 3 piece assembly (plate, bearing housing, plate) but I'm not sure if the bearing housing goes in the front of the x-member or in the rear? Quick example: stock assem is plate, bushing, x-member, bushing, backing plate.</TD></TR></TABLE>
off their site
Old May 23, 2008 | 04:02 AM
Red_ED8's Avatar
Default Re: Front Crossmember Bushings. Are they worth replacing/upgrading (welfarepc)
That's only the diagram of how the bear is assembled internally, It still has 2 more plates you put on either end. I think it goes in like: plate, bearing housing, x-member, backing plate but I'm not 100% sure.
Old May 23, 2008 | 08:40 AM
Ch3mik's Avatar
why spend $200 on just bearings and ONLY eliminate wheelhop?
ETD makes an excellent bar. Gives you clearance , caster adjustment, MAD clearance, bling factor, and ZERO wheelhop.
http://etdracing.com/8891.html
$300
I ran it on my crx for a year. made it SOLID. I tried the solid bushings, spherical bearings, then finally went to the ETD unit. night and DAY difference
saev yourself the trouble and do it right the first time.
Old May 23, 2008 | 09:14 AM
Default Re: Front Crossmember Bushings. Are they worth replacing/upgrading (Ch3mik)
i just figured since i already have somewhat of a good xmember, why not add some dope bearings to it? think that should do the job?
Old May 23, 2008 | 03:15 PM
alscrx's Avatar
Default Re: Front Crossmember Bushings. Are they worth replacing/upgrading (BumbleBee Tuna)
Anyone have pics of the ETD bar on the CRX?
I have one now but it makes alot of noise, Like creaks and sqeaks!
Its a daily driver so it gets annoying! Was wondering if i had the wrong bar maybe
Old May 23, 2008 | 05:31 PM
Ch3mik's Avatar
Default Re: Front Crossmember Bushings. Are they worth replacing/upgrading (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have pics of the ETD bar on the CRX?
Its a daily driver so it gets annoying! Was wondering if i had the wrong bar maybe </TD></TR></TABLE>
mine didnt squeak , whats your suspension consist of and how many miles are on the components. I dont know why I never took an aerial shot of mine before i sold the crx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BumbleBee Tuna &raquo;</TD></TR><TR><TD CLASS="quote">i just figured since i already have somewhat of a good xmember, why not add some dope bearings to it? think that should do the job? </TD></TR></TABLE>
i suppose. although it doesnt let you do caster adjustments
Old May 23, 2008 | 05:45 PM
welfarepc's Avatar
i wouldnt want to run a traction bar with heim joints because of the lack of lubrication. it would be a pain to pack them every week
i started a thread in tech/misc about heim joint boots but didnt get a response yet... shoulda done it in fab i think.
redboost10
Jun 7, 2007 11:45 AM
typeRclass
Suspension & Brakes
May 17, 2005 04:04 AM
zither
Nov 5, 2004 01:13 PM
charjacq
Apr 4, 2002 05:35 PM
wuhungsixxx
Oct 5, 2001 11:03 AM
