*** injectors not firing*** need help asap
long story short, car bogged and died, not comming onto it at all. jdm b16, JDM p30 in a 92 si hatch.
tested everything, getting fuel to the rail, its just that the injectors are not shooting fuel into the cyclinders. they are not getting power, tested with a test light.
a mechanic says it might be something in the distrubuter, but i do not know, is it possible it might be the ECU? how can i check to see which 1 it might be?
please help
ps - once the car bogged and died, it started throwing codes 21 (primary o2 heater) and 41 ( vtec silinoid switch) or something... it also had a code 20 for a long time that i couldnt clear.... HELP
please help
CPS is in the dizzy right? how can i test this?
also how can i test to see if the ecu is putting out power to teh injectors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified »</TD></TR><TR><TD CLASS="quote">bump, im carless atm...</TD></TR></TABLE>
I got the papers here in front of me on how to test it but i dont have the page. PM me on lowmotion and ill take a pic with my phone and send it to you.
i checked all the fuses, nothing that i can see... the funny thing is that as soon as it happened, it started throwing codes 21 and 41, neither of which should make the car not run :?
it also had code 20 too but it worked fine before that for a long time...
since it just died right out, im thinking its something in the distributer, i dont think the ecu would just go for no reason
i tried that, but ill try it again tomorrow... but as of now, im gonna get a dizzy or ecu, still up in teh air as to wat i want to guess at tho... i wish i could test it
