problem replacing lower ball joint (upper ball joint)
I was replacing the lower ball joint which is in... but the upper ball joint just spins when I try to tighten it... do I have to replace it? or should I just impact it?
also, if I replace the upper ball joint can the old be pressed out? or do I need a whole new arm?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by innes887 »</TD></TR><TR><TD CLASS="quote">sometimes the stud on the ball joint need a hex bit to hold it while you tighten the nut. check to see if yours has it</TD></TR></TABLE>
A couple weeks late on the answer
and I have never seen an oem honda ball joint that had a allen key hole on the stud
squeaky
14
Aug 29, 2004 12:08 PM
