FREE AEBS Sleeved Y7 block and Y8 head!
Old May 21, 2008 | 07:22 AM
user 98292739's Avatar
Default FREE AEBS Sleeved Y7 block and Y8 head!
yes of course there is a catch. i have been having head gasket problems since i got the block. Well it turns out the shop that installed the sleeves didnt deck the block so everything isnt flush thus blowing head gaskets. They also drilled out some of the coolant passages. I ran the motor as it is for 3 k and it ran good while i had coolant
so this motor is in working order it just NEEDS decked. I am going to throw in the block for FREE if you buy all the internals. Block alone is $1100 retail and more then that in parts.
AEBS Sleeved D16y7
CP 9.1 pistons
Eagle Rods
ACL bearings
Polished crank
2 10 an bungs on oil pan
New water pump oil pump
Ill throw in 9 arp head studs if you want yes 9 i snapped 1...
all the parts not including the block is over 1k. I want 725 shipped yes 725 shipped for the complete assembled block. Of course block is sold as is...but it does run and will run even better if the sleeves sat flush...
I also have a Built head. Ill throw in the head for FREE if you buy the internals The head has a mild port and polish nothign to rave about ill get more pics of that later. 500 shipped
D16y8 head
Skunk2 Cam Gear
Zex stage 3 105900
Isky Valve Springs and Retainers
Rev Hard Valves
Old May 21, 2008 | 05:09 PM
obo!
Old May 23, 2008 | 10:58 AM
afaf
user 98292739
Jun 8, 2008 09:44 AM
user 98292739
Mid-Atlantic (Sales)
May 23, 2008 10:54 AM
RACEPAK
May 9, 2008 03:08 PM
panda_eh2
Dec 27, 2007 11:32 PM
