integra weather strip
Old May 21, 2008 | 05:00 AM
allmotorek8's Avatar
Default integra weather strip
sup guys i noticed im gettin a little water in my car threw the driver door and in the trunk. so i was thinking of replacing the weather strip around the doors then the trunk? and also i changed my hatch because it had a huge rust hole in it. so i went with the wingless look and i noticed when i wash my car a little soap gets stuck in between the hatch and the car ? anybody know where this leak can be coming from and where i can buy the weather strips? any advice will help
Old May 21, 2008 | 05:10 AM
Default Re: integra weather strip (allmotorek8)
nevermind just found it for anyone that wants to replace weather strips on there car . here u go http://www.jcwhitney.com/Acura...3.jcw
Old Mar 10, 2012 | 02:16 PM
Alcott83's Avatar
Does anyone know how to take the weather stripping off the hatch on da around the window..
Old Mar 10, 2012 | 02:31 PM
KtHaNxBai's Avatar
un lock the trunk shocks and pull off.
Old Mar 10, 2012 | 03:14 PM
TheRealTegger's Avatar
You mean the stuff that surrounds the glass? NOT worth trying. You need to remove the glass from the hatch. And the glass is bonded in, just like the front windshield.
Why do you want to do this? If it's to do bodywork, you're better off to tape off the existing molding and just work around it.
Old Jun 26, 2012 | 03:39 PM
Alcott83's Avatar
yeah thats what im going to have to do.. the weather stripping comes attached to the glass i found out. not worth taking off
Old Feb 8, 2015 | 09:29 AM
Lsm_ProjectEK's Avatar
Not to bring up an old post but im having this problem as well, im getting water in the trunk. The weather strip around the hatch glass is in good condition but the water still gets in. Is there a strip that goes inside one the frame around the glass.
Old Feb 8, 2015 | 12:45 PM
Jimmy's Avatar
Global Moderator
Usually water gets in from leaking taillight gaskets too.
Run a quick search and you'll find tons of info.
Rex89
Jan 2, 2007 06:12 PM
hxtasy
Aug 31, 2005 06:05 PM
buckNasty
Mar 11, 2004 10:17 PM
yusoslo
12
Oct 22, 2003 09:03 PM
integra97R
Oct 3, 2003 09:13 AM
