the best swap
A 99 CRX? I dont think so. Anyways if you want to put a K20 in there I'm pretty sure you need to chop the car and make it longer, I think. I do know that you'll need alot of $$ though.
Get a b18c it will bolt right in with a hasport kit and a few wires, the stock harness
will work and there is alot of parts available for those motors. b18c5r
and it will fit under the hood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixgunsound »</TD></TR><TR><TD CLASS="quote">I'm pretty sure you need to chop the car and make it longer, I think. </TD></TR></TABLE>
Wow, that is sig material
. You don't have to make the car longer or anything like that. You have to replace one off your motor mounts (cut it off and weld a new one on) and use a SIR style hood. Look in the FAQ's before you post, all this is in there.
Boosteddc2gsr
Jul 15, 2003 08:28 AM
