1990 Base Model Hatch Engine options?
Old May 20, 2008 | 08:15 PM
Sabbotage's Avatar
Default 1990 Base Model Hatch Engine options?
I have a 90 Hatch base model with a 4 speed tranny and my engine is eating around a quart of oil every 200 miles. What engines besides the stock D15 will bolt right up to the 4 speed tranny with no wiring modifications or any other mods for that matter?
I tried searching but found mixed results. This is my beater car so I just wanna swap a new engine in with the least amount of effort possible. I dont wanna have to do any wiring or changing ECUs or anything crazy like that. Thanks in advance! I'm new to the civic end of things and i'm used to preludes.
Old May 20, 2008 | 08:50 PM
pandarex's Avatar
Default Re: 1990 Base Model Hatch Engine options? (Sabbotage)
the easiest engine would be any sohc non-vtec engine from 88-91 civic/crx. any d-series will bolt up to you trans, and if you keep all the IM and exhaust and such from yours than you dont need wiring changes.
Old May 20, 2008 | 09:39 PM
whiteknightef's Avatar
Default Re: 1990 Base Model Hatch Engine options? (pandarex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pandarex &raquo;</TD></TR><TR><TD CLASS="quote">the easiest engine would be any sohc non-vtec engine from 88-91 civic/crx. any d-series will bolt up to you trans, and if you keep all the IM and exhaust and such from yours than you dont need wiring changes.</TD></TR></TABLE>
X2
Old May 21, 2008 | 04:36 AM
Sabbotage's Avatar
so a SOHC ZC swap from hmotors would work then? I saw a SOHC ZC swap on hmotors listed for 88-91 civic/crx that looked like it would work.
Heres the link:
http://www.hmotorsonline.com/s...30020
Old May 21, 2008 | 05:50 AM
~sp33~'s Avatar
EFB055
If you were to use that intake manifold you would have to swap to MPFI from DPFI. But i guess you could sell it, and use your DPFI IM.
Old May 21, 2008 | 06:02 AM
91JDMTeggy's Avatar
Default Re: (~sp33~)
yah, but in my opinion, i would just go through with the MPFI wiring, cuz if you plan on doing <U>any</U> swap in the future..... you need MPFI. i just did it in my dx sedan with a b16a and it went pretty well. hope this helps you out man.
Old May 21, 2008 | 06:39 AM
Sabbotage's Avatar
ahhh ok thanks....i think im just gonna check some salvage yards around here first and see if i can find a D15 to swap over. if not maybe ill get the ZC and just swap IMs.
Old May 21, 2008 | 07:21 AM
gursh d's Avatar
Default Re: (Sabbotage)
DPFI to MPFI might sound confusing and alot of work, but if you have the patience and label your wires, it's not that difficult. Plus if you ever wanted to swap in a b-series or ZC your already wired for MPFI. Just my .02
good read: http://www.fourthgenhatch.net/mpfi.html
Old May 21, 2008 | 09:03 AM
Sabbotage's Avatar
Default Re: (gursh d)
Thanks for the link. I dont see that wiring being a big deal. I've rewired my old prelude for Vtec and everything so the wiring isnt a big deal. I was just being lazy and didnt wanna have to do it for just a daily driver
Old May 21, 2008 | 10:51 AM
91JDMTeggy's Avatar
well after the mpfi swap, you'll have a quicker lil daily driver haha
Old May 22, 2008 | 05:41 AM
Sabbotage's Avatar
Default Re: (91JDMTeggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91JDMTeggy &raquo;</TD></TR><TR><TD CLASS="quote">well after the mpfi swap, you'll have a quicker lil daily driver haha
and worse on gas it wouldnt be that much worse though but im lookin for the best gas mileage i can get....
Anyone have a D series for sale in PA? I'm having trouble finding one locally.....
Edit: mine borns oil so bad its like its got Vtakkk....it bogs down so bad and once the cloud clears it suddenly takes off and truely feels like vtec kickin in
Old May 22, 2008 | 05:57 AM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sabbotage &raquo;</TD></TR><TR><TD CLASS="quote">
I have a d16a6 w/ tranny out of a 91 CRX SI. Completely stock, about 180K, ran fine before I pulled it out. Tranny has no grinds.
Make an offer and its yours. I'm in Southern Maryland, 20650. Its about a 3 hour drive south from philly.
Old May 22, 2008 | 06:52 PM
Sabbotage's Avatar
well i managed to score a D16 out of a 93 CX hatch tonight for FREE. im pretty excited about that.
Now what i need to know is what all do i need to do this swap?
Correct me if i'm wrong but i was assuming i need to do the MPFI wiring found on forthgenhatch.net, i need an Si ecu or one that will work with that engine and i need an Si resistor box......I think this is all i would need to do it. Someone correct me if im wrong. Thanks!
BTW, i have a P07 ECU from a 94 VX hatch that i'm not sure would work for this swap or not...
if someone could tell me what i need that would be appreciated. Thanks again guys
EDIT: turns out the engine is a D15B8 so ill just swap my IM and dizzy and I should be good. I may still wire for MPFI though but money is an issue so i may have to hold off on that.
Modified by Sabbotage at 1:04 PM 5/23/2008
antihero12
Classic Hondas
May 6, 2011 08:09 PM
Psycho719
10
Aug 27, 2010 01:51 PM
heminick
Sep 12, 2007 07:24 PM
bauer10
Apr 21, 2006 12:37 PM
coolusername
12
Jun 24, 2003 01:08 PM
