is compression of 150 good?(all 4)
Old May 20, 2008 | 07:07 PM
G2_Fella's Avatar
Default is compression of 150 good?(all 4)
just had my mech did a compression test on my car. he checked all four spark plugs and one of them were a lil rusty. spark plugs only 3 weeks old. knuckle head forgot to do the leak down test for me. he recommend me to do head gasket and replace radiator at the same time.
labor: 150
head gasket kit: 80? will call dealer to check
resurface the head: 60
radiator: 130
how many different types of bad head gasket is there? from bad to worst?
Old May 20, 2008 | 07:15 PM
elektronsi's Avatar
Default Re: is compression of 150 good?(all 4) (G2_Fella)
a bad head gasket is a bad head gasket, theres really no in b/w
Old May 20, 2008 | 07:22 PM
G2_Fella's Avatar
Default Re: is compression of 150 good?(all 4) (elektronsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elektronsi &raquo;</TD></TR><TR><TD CLASS="quote">a bad head gasket is a bad head gasket, theres really no in b/w</TD></TR></TABLE>thanks elektronsi.
Old May 20, 2008 | 07:30 PM
Padawan's Avatar
Darth ModerVader
Can you post photos of the plugs? I don't necessarily think your gasket is a problem.
Old May 20, 2008 | 07:32 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2_Fella &raquo;</TD></TR><TR><TD CLASS="quote">just had my mech did a compression test on my car. he checked all four spark plugs and one of them were a lil rusty. spark plugs only 3 weeks old. knuckle head forgot to do the leak down test for me. he recommend me to do head gasket and replace radiator at the same time.
labor: 150
radiator: 130
how many different types of bad head gasket is there? from bad to worst?</TD></TR></TABLE>
A simple "rusty" spark plug means nothing. Perhaps your wires don't seal well and some water or condensation worked its way into the tubes... Unless the electrode itself was rusty, I wouldn't be concerned. If it WAS rusty then you should see low compression on that cylinder assuming the headgasket is the cause. You would also see steam in the exhaust, clean piston tops, noticeable drop in coolant level, increase in engine temp (read on the gauge), rapid cooling system pressure build up, etc. You can't tell me he determined that 150psi on all 4 cylinders + rusty plug tip alone means bad headgasket. If he was any sort of a decent mechanic he could at the very least use a block tester to confirm combustion chamber gases in the cooling system... doesn't sound to me like a good call.
Old May 20, 2008 | 08:23 PM
G2_Fella's Avatar
Default Re: is compression of 150 good?(all 4) (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Can you post photos of the plugs? I don't necessarily think your gasket is a problem. </TD></TR></TABLE>that's the only problem i'm having with h-t, posting pix. i don't know a damn thing about it. if i knew about it, i would be showing off my ride like everyone else.
i got to get my act together and get with the program. move with the crowd.
Old May 20, 2008 | 08:25 PM
G2_Fella's Avatar
Default Re: is compression of 150 good?(all 4) (Hybrid96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">
A simple "rusty" spark plug means nothing. Perhaps your wires don't seal well and some water or condensation worked its way into the tubes... Unless the electrode itself was rusty, I wouldn't be concerned. If it WAS rusty then you should see low compression on that cylinder assuming the headgasket is the cause. You would also see steam in the exhaust, clean piston tops, noticeable drop in coolant level, increase in engine temp (read on the gauge), rapid cooling system pressure build up, etc. You can't tell me he determined that 150psi on all 4 cylinders + rusty plug tip alone means bad headgasket. If he was any sort of a decent mechanic he could at the very least use a block tester to confirm combustion chamber gases in the cooling system... doesn't sound to me like a good call.</TD></TR></TABLE>
so should i just replace the radiator? that, i can do myself. maybe i should do that first.
zcmotor
15
Feb 17, 2008 10:57 AM
gsrHB
May 4, 2007 03:38 PM
raphael
Feb 16, 2007 10:21 AM
Stewie
Jun 11, 2003 04:26 PM
