I need help with my swap
Old May 20, 2008 | 06:19 PM
crazydude107's Avatar
Default I need help with my swap
So I have a 1988 Crx Si and I am swapping in a B18B1 engine from a 1994 integra the car is still complete ( it was in a front end accident and is a write off). So basicly whats happened so far is I purchased the efb2 kit from hasport because it has a hydro trans, and from what I've gathered I can get a jumper harness to work with the stock ecu plug and also a jumper harness for the distributer.
I'm not sure if I just have to shorten the integra shift linkage or make a hybrid of the two from the crx and integra?
Also can I use the integra axels in the crx si hubs?
Thank you
Old May 20, 2008 | 06:40 PM
SlipGear's Avatar
Default Re: I need help with my swap (crazydude107)
The integra axles will work with your hubs, and you can get your jumper harness and everything from http://www.rywire.com. Hasport sells shift linkages, but i have read you can use DA linkages if you shorten them like 2 3/4"
daprolistic
Mar 22, 2011 08:24 PM
sleepercrxk24
Sep 14, 2010 09:02 PM
upallnight
13
Mar 23, 2007 12:12 PM
TopStreetDSM
18
Jan 2, 2005 02:55 PM
NsX_CrX
May 17, 2004 05:48 AM
