miss shifting REPAIR UPDATE.....????
Old Jul 15, 2002 | 11:27 AM
JDM_ITR's Avatar
Default miss shifting REPAIR UPDATE.....????
I miss shifted from 3rd back into 2nd about two nights ago. Luckily, i didnt gas it in 2nd gear, i just released it back out...but it still redlined badly. Anyways, shortly after that, my car had a rougher idle...and you could also hear it back firing. Something else I noticed was that everytime i started the car, for about the first two minutes, my car would "sputter" when you pushed on the gas....felt like it wasnt going anywhere......
I was almost 100% sure that I had to have bent a few valves, since all this happened right after I miss shifted. Well i stayed up until 6 this morning changing out the valves (both intake and exhaust) and the head gasket...We finally finished, and STILL the same problem. Now im thinking that it wasnt a bent valve....
Now im thinking im having some sort of fuel problem because ALL of my exhaust valves were BRIGHT white....does anyone know y??? My guess is that im running too lean......Im now im guessing that my car is sputtering and idling funny because im not getting enough gas.....what do you guys think?? What should i check/ do next??
Old Jul 15, 2002 | 11:31 AM
Reid's Avatar
Global Moderator
Default Re: miss shifting REPAIR UPDATE.....???? (JDM_ITR)
Are you sure that your cam gears are aligned properly?
Tweakmeister's Avatar
did you check the head to make sure it was good?
how about the piston tops?
fuel can be manipuated via a FPR + gauge (B&M combo at optauto.com for under $100).
are you running a v-afc?
Old Jul 15, 2002 | 11:37 AM
JDM_ITR's Avatar
Default Re: miss shifting REPAIR UPDATE.....???? (Tweakmeister)
yes, cam gears are alligned properly. No sign clearance problems between the valves and pistons. No vafc....wat do you think guys?
Reid's Avatar
Global Moderator
What mods do you have?
Just so we're all on the same page....
EDIT:
Hey wait a minute, every time I install new valves I have the head redone to accept the new valves, but maybe that's just me.
[Modified by Reid, 10:39 AM 7/15/2002]
Old Jul 15, 2002 | 11:44 AM
reefer_bob's Avatar
Default Re: miss shifting REPAIR UPDATE.....???? (Reid)
Did you inspect your valve seats and valve guides when you replaced the valves? There could still be leaks in there, and damage from a bent valve... Were there any impact marks on the top of the piston?
Old Jul 15, 2002 | 11:45 AM
JDM_ITR's Avatar
Mods:
B18b block
B16 head
CTR pistons
JDM 4into1
ITR AEM CAI
Old Jul 15, 2002 | 11:49 AM
Reid's Avatar
Global Moderator
Sounds like valves weren't the only thing damaged.
Head is damaged, most likely.
Old Jul 15, 2002 | 12:07 PM
JDM_ITR's Avatar
Mods:
B18b block
B16 head
CTR pistons
JDM 4into1 headers
ITR AEM CAI
Old Jul 15, 2002 | 12:08 PM
JDM_ITR's Avatar
warped head???
Old Jul 15, 2002 | 12:22 PM
Reid's Avatar
Global Moderator
warped head???
That I seriously doubt.
I'm thinking your valves aren't sealing properly.
Old Jul 15, 2002 | 01:11 PM
Evil DOHC's Avatar
Compression check and leak down is the key point here....
Also you said you replaced the valves, there is no such a thing as just getting new or used valves and poping them in. You have to seat the valves with a special grinding compound or take it to the machine shop to cut. Personally, I would do a comp and a leak down, and go from there. Also are you throwing any codes?
EVIL
Old Jul 16, 2002 | 09:41 AM
JDM_ITR's Avatar
Default Re: miss shifting REPAIR UPDATE.....???? (Evil GS-R)
Is this true, you have cant just pop in new valves, even if they are OEM? My next step will be to do compression check and leak down...ill let you guys know from there.
Old Jul 16, 2002 | 10:08 AM
skafia's Avatar
25 Year Member
I misshifted my car from 3rd into 2nd with full throttle and a blown clutch was just the result.
That sputter you hear when you turn your car on is the "throw-out bearing."
Old Jul 16, 2002 | 10:21 AM
done's Avatar
did you break a valve guides???
check the seals and guides. i busted 2.. had head sent to machine shop to be fixed..now it runs like a champ..
[Modified by Jordo, 1:23 PM 7/16/2002]
redline303
Aug 25, 2010 04:56 PM
b18punk
Apr 3, 2005 07:48 AM
dxhatch93
13
Jun 18, 2003 05:48 PM
89 CRX SI
Apr 28, 2002 02:16 PM
