HELP with my sohc
Old May 20, 2008 | 12:10 PM
NVmyEK's Avatar
Default HELP with my sohc
i have a d16z6 head on a y7 block. obd1 dizzy and an p2p computer. well recently my car has been screwing up. sometimes when the motor and tranny get warm (in neutral) i slightly rev it and it bounces off like rev. limiter at 1800-2000 rpm. and then the car in gear jolts when u let off the gas and give it gas. now is this a bad trans & clutch or is this the ECU?
Old May 20, 2008 | 12:43 PM
som3on3_10's Avatar
Default Re: HELP with my sohc (NVmyEK)
Check the timing belt and make sure that your timing is correct. How does the car idle? Any CEL's?
Old May 20, 2008 | 01:00 PM
NVmyEK's Avatar
Default Re: HELP with my sohc (som3on3_10)
idle is kinda high. around 1100-1300 rpm. umm its around 4.5 degree's adavance on cam gear. and lights are on for i believe knock sensor but like i said i had this motor done for a month. and just started acting up.
Old May 20, 2008 | 02:01 PM
wmac's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVmyEK &raquo;</TD></TR><TR><TD CLASS="quote">
i reccomend using a p28 to go with the z6 head/distributor
also, what intake manifold? y7 injectors are kind of small for vtec head 190cc/240cc
Old May 20, 2008 | 04:00 PM
NVmyEK's Avatar
Default Re: (wmac)
i have the z6 manifold with the z6 injectors. i let it run for a while and sure s**t when i rev'd it a lil it basically bounced off rev limiter.. smelt really rich or lean. then i let it idle.. which idle is a lil higher where it should be. but the funny thing is you can give it more gas and it by passes the like rev lmiter (rev control) stage. idk any ideas?
Old May 20, 2008 | 04:19 PM
wmac's Avatar
then you should probably get an obd2 to obd1 harness and p28 so you'll be all obd1 instead of half and half
Old May 20, 2008 | 04:22 PM
NVmyEK's Avatar
Default Re: (wmac)
that wat i was thinking too. but do u think that will solve it?
Old May 20, 2008 | 07:54 PM
wmac's Avatar
can't say for sure if it will fix your problem
but I wouldn't expect it to work well with OBD2 ecu and ODB1 distributor + ODB1 sensors on intake manifold.
could be a vacuum leak... or a bad sensor... or an ODB1 sensor sending an ODB2 ecu a signal that doesn't make sense...
Old May 20, 2008 | 08:11 PM
NVmyEK's Avatar
Default Re: (wmac)
very true. well friday will tell wat the hell is up. when the p28 goes in.
Old May 21, 2008 | 06:47 AM
wmac's Avatar
yeah, post up any cel the p28 gives
Old May 21, 2008 | 07:21 AM
speedooo's Avatar
Default Re: (wmac)
the p2p will run it just fine except itll throw a couple cel's obd1 ecus dont read for. sounds like your map sensor is screwed up or maybe the iacv is bad. is this in an ek dx/lx/cx that comes stock w/ a y7?
Old May 21, 2008 | 12:47 PM
NVmyEK's Avatar
Default Re: (speedooo)
its in a 96 civic ex. y7 lower end z6 head. im thinking its the idle control valve since it threw a code for that and o2 sensor
Frost7177
Nov 4, 2009 09:05 PM
93accordsleeper
Oct 7, 2008 07:40 PM
purplecrx
12
Jul 19, 2006 01:47 PM
Doug684
Jun 18, 2004 10:45 AM
jwork101
Apr 3, 2003 11:39 AM
