gsr in a 99 ek...
Old May 20, 2008 | 11:11 AM
premier_ek9's Avatar
Default gsr in a 99 ek...
i swapped a obd1 gsr motor in a 99 ek.. i cant find anyone sellin a ex or si harness so i wanna use the stock dx harness.. how do i rewire the obd1 distributor and on the gsr the iacv is a 2 wire plug while my dx harness has a 3 wire plug for the iacv which wire do i have to eliminate... im using a p28 so i would appreciate any help..
Old May 20, 2008 | 11:51 AM
boost'd_crx's Avatar
Default Re: gsr in a 99 ek... (premier_ek9)
for the iac. first off you need to move pin a14 to a12 and remove pin a13 from the ecu plugs. then you need the 2 wire circle plug from the gsr iac. connect the yellow/black to green/black, then black/blue to the black wire. you dont need the orange wire.
for the dizzy
obd2------------------>obd1
1.yellow/green --> yellow/green
2.blue/green --> light blue or blue
3.orange/blue ---> orange/blue or green
4.orange ---> orange or yellow
6.blue/yellow ---> blue/yellow or white
7.white/blue ---> white/blue or red
8.white ---> white or black
9.blue ---> blue
10.black/yellow ---> black/yellow
Modified by boost'd_crx at 1:17 PM 5/20/2008
Modified by boost'd_crx at 1:18 PM 5/20/2008
Old May 20, 2008 | 01:47 PM
just.me.ek5's Avatar
to the OP, what was needed to swap the gsr into the ek chassis?
Old May 20, 2008 | 08:39 PM
Default Re: gsr in a 99 ek... (just.me.ek5)
you dont need much.. i used the stock mounts... u just need an L bracket from a si or gsr and on the camgear side of the motor u need the piece of a si motor that bolts into the block with the 2 bolts that stick up into the mount... and u need a ac bracket from a gsr or si or else the motor jumps up on that side and puts a dent in ur hood
SpeedOFsmell
Jan 16, 2015 11:25 AM
95f22a1
22
Feb 2, 2009 10:12 AM
Mr. LS VTEC
Oct 25, 2006 01:36 AM
lshatch1.8
Oct 8, 2006 03:01 PM
civicexstacy
Jul 31, 2005 06:35 PM
